HELP! Bumper bolt stripped
Old Dec 11, 2008 | 12:18 PM
RedEG8's Avatar
Default HELP! Bumper bolt stripped
Im talkin about the 5 bumper bolts that hold up the bumper near the rad 2 of them are stripped...what are my best options on getting them out??
thanks guys
Old Dec 11, 2008 | 12:36 PM
Jas9848's Avatar
if the head of the bolt/screws are still there just get some vice grips and turn them out. dont forgot to use rust penetrant on them. if they are broken off in the threads you will have to drill and tap.
pkdog167's Avatar
thanks guys
Vice grip work for me, if not drill it out.
Old Dec 11, 2008 | 12:37 PM
Paul-R's Avatar
vice grips if that doesn't work drill them out ....
Old Dec 11, 2008 | 02:02 PM
itsmejto's Avatar
dremmell cut off tool
Old Dec 11, 2008 | 04:09 PM
rallyeman's Avatar
That tool will do:
At least it did the jod for unbolting my bumper bolts!
Old Dec 11, 2008 | 08:59 PM
RedEG8's Avatar
I tried with vise grips, the damn thing is stuck on there good....im gonna try to dremmel cut it..but how?
Old Dec 11, 2008 | 09:24 PM
Civic9390's Avatar
i use vise grips and replace the stripped ones with a nice 10mm bolt and a big washer ;-) Won't Strip agian.
Old Dec 11, 2008 | 09:31 PM
SImadness's Avatar
dont strip them in the first place, use hte right tools
i would grind them flat
Old Dec 12, 2008 | 07:32 AM
RedEG8's Avatar
how would i grind them flat?? or would drilling them out be better?
Old Dec 12, 2008 | 07:49 AM
1LowSol's Avatar
Drill and then tap them, Then go buy new screws for the newly tapped holes.
Old Dec 12, 2008 | 09:39 AM
RedEG8's Avatar
what's the best size drill bit?
Old Dec 12, 2008 | 11:53 AM
happyabortion's Avatar
for 10mm used a 5/16 drill bit and a reverse drill bit. to get a broken bolt off of me ac compressor. you sure vice grips wont do it? try come big vise grips and a cheater pipe on them? hope this helped. good luck!
0utaSight
Aug 20, 2007 03:32 PM
sohctodohc
Apr 11, 2006 01:06 AM
cloudx71
Apr 8, 2006 07:54 PM
HomeDepotMade
Jan 21, 2006 12:39 PM
pdiggitydogg
Jun 25, 2003 01:35 PM
