anyone boost a h22 with a 16g turbo?
Im in the process of doing a h22 swap into my 4th gen prelude. I was thinking about boosting it when its complete. Did anyone boost there h22 with stock internals with a 16g turbo? Ive heard around from the site that a 1st gen 4g63 turbo manifold will fit the h22 with a little modification. If anyone has done this b4 a little help with what i need to do would be awesome. wanna get the facts and list of parts b 4 i jump into something.
I have had the DSM setup on my f22's with the even ports. The exhaust manifold studs line up fairly well but they do require some modification. The exhaust ports on the head line up faily good but it can not hurt port match them. I do not think the h22's will work. IF you get it too work I have a ported oxygen sensor housing for the turbo and a complete downpipe setup for 92-96 Prelude.
I had this almost done, pretty much every part bought. I was going to use the bigger evoIII 16g but still, pretty close. I went through all the pain in the *** research and I bought pretty much everything, I actually still have some stuff. PM me if you want some info, I could probably help you out and walk you through building the car. My goals were about 240+whp/wtq
