turbo h22
Old Feb 6, 2002 | 11:10 AM
bananacruzier's Avatar
Default turbo h22
me and some friends are builting a h22 motor for drag use and i want to kno what size and brand i should go with for a turbo. it's fully built and can hold up to 23lb of boost. our goal is to hit into 10's 1/4 mile. what size turbo do you guys think will be able to get the job done. need a turbo that will be able to hold up alot of boost with no problems. what do you think?
Old Feb 6, 2002 | 11:11 AM
b18bturbo's Avatar
Default Re: turbo h22 (bananacruzier)
t4 60-1 frm turbonetics .
Old Feb 6, 2002 | 01:31 PM
DLB1994's Avatar
Default Re: turbo h22 (b18bturbo)
yep
Old Feb 7, 2002 | 11:04 AM
Default Re: turbo h22 (DLB1994)
thanx, guys i was thinking about the t4 myself. now does that with a complete package or just the turbo and where is a good place to get it from.
Old Feb 7, 2002 | 11:09 AM
Rob03Pro5's Avatar
Need to learn a thing or two more about turbos before attempting to build an all-out 10sec H22.
What do you mean by complete package?
Old Feb 7, 2002 | 11:31 AM
b18bturbo's Avatar
Get the t4 60-1 from turbonetcics. Go with a Prelude manifold designed with a t4 flange any of them that can flow well. I really liek the the Revhard and KIWI ones.
Next step size a intercooler for you. If this car is daily driven use a air to air intercooler. pretty larger with least amount of pressure drop
If all out drag get a spearco water to air intercooler. It make install easy since you dont have to rout so much.
For the DP jsut custom build you one and dump it somewhere.
For Wastegate get a tial 46mm should do you jsut fine with 20psi spring or so
For BOV your choice make sure it can handle high boost though. highly reccommend GREDDY TYPE R or TIAL
other than that you pretty much set. Choose a good ecu setup and fuel easy 10s with h22a in civic.
Old Feb 7, 2002 | 11:32 AM
rtype11's Avatar
UPRD.com has one t60-1 left from turbonetics for like 770, my friend has built a h22 and he is running a....hold on you wont believe this.......T78!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 7, 2002 | 09:39 PM
Markaccord95's Avatar
Default Re: turbo h22 (rtype11)
T78? what does it spool at ? 6500rpms? jeeeesus
my h22a manifold, SFP, good poo poo there http://www.accordclub.com/turbo
exh22
Jul 26, 2007 06:21 AM
GroundAssault
Mar 22, 2007 03:57 PM
ludekid4323
Dec 6, 2006 11:57 AM
pentaq
Jul 31, 2005 08:41 AM
IntegraPrez
Nov 2, 2004 03:42 PM
