Will a VTEC distributor fit on an LS motor? OBD2.
Old Dec 11, 2008 | 10:51 AM
DuongBros.'s Avatar
Default Will a VTEC distributor fit on an LS motor? OBD2.
My distributor took a crap on me this morning, but my friend has an OBD2 distributor laying around, but I believe it's from a GSR.
Will the VTEC distributor fit on my OBD2 LS motor? thanks.
Old Dec 11, 2008 | 10:57 AM
neardon's Avatar
I'm a Jackass
It will fit on, but the bolt holes wont match up so you will only be able to bolt down 1 maybe 2 of the arms.
Old Dec 11, 2008 | 11:14 AM
DuongBros.'s Avatar
so would it be able to endure a 5 minute drive back to my place, safely?? It's raining and cold outside, and I need to get it off the streets of Phillyy
Old Dec 11, 2008 | 11:19 AM
Circusraven's Avatar
It should be able to, just make sure it's sitting flush, and like the guy said, you might only be able to get a couple of bolts on it at the most. I ran a sawed off LS distributer on my B16 for a little while, so they do match up back and forth, it's just the bolt patter that's obviously different.
What's wrong with your dizzy?? you should try switching out the internal coil from your messed up one with the one from the good GSR. My dizzy took a crap on me, and it was the internal coil that went bad.
Old Dec 11, 2008 | 11:30 AM
DuongBros.'s Avatar
Well, the car was driving fine on the way to the store. Turned it off, went to the store, turned it on...then started shaking and sounded like it was dying, then it died. Car turns over, but just doesn't ignite.
We checked my sparkplugs and they're still in good shape. How can I tell if the internal coil is bad? I don't wanna spend like $200 on a new dizzy if it's something else.
All my lights turn on and whatnot, and car primes.
Old Dec 11, 2008 | 11:43 AM
neardon's Avatar
I'm a Jackass
It could be the coil or the ignitor, both are inside the distributor and both can be tested using a haynes or service manual. Google "Hondahookup manuals" for a free one.
Old Dec 11, 2008 | 11:53 AM
DuongBros.'s Avatar
I'm just looking for a new dizzy right now....kinda pricey. Thanks for the help though!
Old Dec 11, 2008 | 12:43 PM
LS stretch's Avatar
if your friend has the gsr dizzy that works, just take the "guts" out of it and put them in your ls dizzy casing
Old Dec 11, 2008 | 02:31 PM
IN VTEC's Avatar
I think I got you covered. Make me an offer.
http://www.hondamarketplace.com/show....php?t=2441680
Old Dec 11, 2008 | 05:11 PM
DuongBros.'s Avatar
thanks for the offers, but I wish you got to my thread earlier.
Got a new one with all the components for $175.
Car is out of the ghetto streets of Philadelphia haha
njmad
Jun 28, 2012 06:22 AM
dapek
Dec 17, 2008 07:30 PM
n-line4
Aug 3, 2006 03:20 PM
greenDC2
Dec 22, 2005 10:17 AM
EKB18BPR3
Jan 23, 2005 01:34 PM
