No Turn Signals, No Hazard...
Old Dec 11, 2008 | 10:48 AM
Turbo95Hatch's Avatar
Default No Turn Signals, No Hazard...
Been doing some searching, think I've got a laundry list of things to check on my next day off, just wanted to make sure I cover all bases. Car is a 92-95 EX coupe.
Hazard switch:
could either be unplugged and/or bad
Actuator on column stalk:
could be bad
Flashing Lights Relay:
could be bad. Where is this particular relay located? I'm thinking I remember driver side kick panel area, but not for sure on that.
Can't find a specific fuse for turn signals and/or hazards, if they exist, they are not labeled specifically for those, so what it might be and location would help a ton, I.E. underdash or underhood.
Thanks in advance.
Old Dec 11, 2008 | 10:57 AM
BlueIntegraBoy's Avatar
Sounds like a bad hazard switch. The turn signal relay is on the front of your fuse box. It's a black rectangular box.
Old Dec 13, 2008 | 06:52 AM
Thank you.
Old Dec 14, 2008 | 01:46 PM
didn't get around to testing the hazard switch because, go figure, I check for the relay just to know location and I see an empty slot... slot says "turn" and is square with what appears to have 3 posts... I went to the auto parts store and they show a round relay with two post design for a 94 EX, which I have. Obviously, I learned at a young age a round peg doesn't go in a square hole and vise versa, not to mention the wrong number of posts... any help?
Old Dec 14, 2008 | 04:47 PM
anyone?
Old Dec 14, 2008 | 05:16 PM
sde780's Avatar
Bump for a local dude
Old Dec 15, 2008 | 11:32 AM
acquired a relay and wahla... i have signals
JTR
Jan 11, 2015 04:33 AM
Paul 631
Dec 25, 2011 07:19 AM
mikeja
Oct 22, 2011 11:30 AM
92eg_b16
Oct 19, 2008 12:52 AM
mattcivic
Jan 13, 2005 05:19 PM
