powerchamber whale penis installation questions
Old Dec 11, 2008 | 08:15 AM
bsampson's Avatar
Default powerchamber whale ***** installation questions
hey guys my password JDM powerchamber whale ***** for a 98 GSR is shipped and im going to be installing it shortly and i am a total noob to installing things. This is going to be my first bolt on ever lol and to someone who could help me or someone that has this intake Any tips to installing? does it have directions to installing? What tools should i have ready? and anything i should know? and if u really want to a nice little tutorial would be amazing!
thanks a million!!!
Old Dec 11, 2008 | 08:23 AM
Jas9848's Avatar
should come with instructions. look at the pics online to figure out which way it goes. you will basically need a 10mm socket, ratchet, extension, flat head screwdriver and some needle nose pliers
Old Dec 11, 2008 | 11:05 AM
JdM-tEg-916's Avatar
Welps all you reallie need is 10mm socket, rachet, flathead or maybe a four head, pyleers, extention,
you use the 10mm with the extention, you are goin to take out 3 bolts around the intake box, then take out the intake arm with a flat or four head near the Throttle body.
then if you have a aftermarket hose that connect from the intake to the valve cover, pull out the OEM one out by hand first, if it dont work pull it with plyers.
then attach everything else with common sense, then everyting should work
if an problems PM me
Old Dec 11, 2008 | 11:17 AM
redGSRguy's Avatar
Might have to remove the fender liner to take out the stock resonator. Then just stuff that whale ***** in.
Old Dec 11, 2008 | 03:48 PM
VegasInvasion's Avatar
I'm Huge In Japan
Cheers.
Old Dec 11, 2008 | 10:25 PM
bsampson's Avatar
bump... help to someone who has installed one... i have 2 questions and i need to put it in by tomarow morning!!! This is like an emergency and i really cant mess this up..
1.) What is this and where does this go?
2.) Which little black rubber thing do i use to put in the intake? and which way does it go in? And Where does this little peice of metal go? and which way? and what do i do with the other rubber things that doesnt go into the intake?
3.) Do i have to separate these two pipes? how does this work? the intake came with like a black tube or a hose this go over this top tube? or both tubes? do i have to take one of the tubes out? whats the process here.?
Thanks so much and im sorry im such a noob this is jsut my first bolt on and i dont want to mess anythign up!!!
Old Dec 11, 2008 | 11:43 PM
bsampson's Avatar
im still confused on this part!!! do i really have to break those two lines apart and take out the top one?
Old Dec 12, 2008 | 12:04 AM
bsampson's Avatar
bump...im goin to bed pelase someone read the above few posts!!! ^^^ i need to know this before like 10 or 11 tomarow please! i really need your help HT!!! thanks!!!!
Old Dec 12, 2008 | 10:59 AM
bsampson's Avatar
bump!! plz help!!
Old Dec 12, 2008 | 11:51 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Why do people continue to buy this Gimmick Intake?
What's this thing still run like $280 from Password?
All you need is a 2 - 3 Inch Piece of pipe and a filter, or better yet a V-Stack. Cheaper and will make better power!
Old Dec 12, 2008 | 06:46 PM
Outrun's Avatar
A whale's ***** looks nothing like that. Don't know why they're called that. I'll check my friend's 94 GS-R. I don't remember him having two lines going into the intake like that.
Old Dec 13, 2008 | 12:56 PM
pkdog167's Avatar
[/QUOTE]
The top pipes is vacumme hose which you will not be use because they provide you a new hose. and I forgot where's the bottom pipes goes to, but there's coolant in the line. So you have two option to do it.
1) You can just leave both pipe and use the hose they provide to connect the intake and the vavle cover.
2) If you chose to take out the pipes, you can juse disconnect both pipes and you will need to add back some coolant and bleed the system.
drjondurst
29
Apr 24, 2005 03:21 AM
Btothe3rdDegree
Jan 28, 2005 11:32 AM
DeeJay
Mar 11, 2003 09:24 AM
