itr pistons..can i go turbo????
Old Dec 11, 2008 | 12:23 AM
thegeezerkid's Avatar
Default itr pistons..can i go turbo????
i got a ls v with itr pistons is it safe to throw a turbo on my engine...???
Old Dec 11, 2008 | 08:38 AM
BLU CIVIC's Avatar
Track Advocate
yes
Old Dec 11, 2008 | 08:53 AM
MyHotsh's Avatar
It depends on how high your compression is at..
High compression and turbo..
What does your setup consist of ?...Ls block with what head? B16 , GSR or TYPE R ?
Old Dec 11, 2008 | 09:05 AM
BLU CIVIC's Avatar
Track Advocate
nope...proper tuning can do wonders
Old Dec 11, 2008 | 09:08 AM
tnez's Avatar
ITR's go turbo all the time... but the lower your compression is, the higher you can boost without worrying about breaking ****. so yes... you can turbo.
Old Dec 11, 2008 | 09:14 AM
MyHotsh's Avatar
Of course with proper tuning you can do anything.
ITRs compression are around 10.8 (someone correct me if im wrong) thats why they can turbo it.
Ls/VTEC with ITR piston, depending on the head. The compression will be higher then a stock ITR...
Thats why i asked what his setup was...
http://www.zealautowerks.com/
Old Dec 11, 2008 | 09:50 AM
stickyicky's Avatar
true...but i doubt the 91 premium octane we got in cali will be sufficient enough for a high compression turbo set up...he'll have to pump some higher octane...
thegeezerkid
Dec 11, 2008 08:05 AM
iheartmyej8
May 25, 2007 09:47 AM
94typeR
Mar 27, 2007 08:03 PM
ITR_HO
Feb 6, 2007 02:45 PM
tilt.
Oct 25, 2005 08:10 AM
