itr pistons..can i go turbo????
Old Dec 11, 2008 | 12:21 AM
thegeezerkid's Avatar
Default itr pistons..can i go turbo????
i got a ls v with itr pistons and i want to throw turbo on my engine...would it b a bad idea...i know u have to go low comp but im just asking...
Old Dec 11, 2008 | 05:14 AM
thabao's Avatar
do you have JDM or USDM ITR pistons? USDM pistons in your set up would give you about the very high 10.8or9 area. JDM will give you low 11.2or3.
but like i always say, a good tune will get you anywhere. you can turbo it, just tune it well.
Old Dec 11, 2008 | 05:35 AM
Jas9848's Avatar
i wouldnt do it with those pistons in there. compression will be high and likeniness for detonation will be high as well. you could get away with a low boost setup on a good tune but its still risky.
Old Dec 11, 2008 | 06:19 AM
JDM 98 GSR's Avatar
^x2
Old Dec 11, 2008 | 06:55 AM
HONDRETTI's Avatar
no, it would not be a bad idea. make sure you tune it immediately after everything is installed.
Old Dec 11, 2008 | 07:02 AM
twentyhurtz's Avatar
not to butt in, but i have a jdm b18c motor, its all stock internals, would it be bad that i have been slowly building a turbo kit for this motor? i can't even get away with low boost 6-7 lbs?
Old Dec 11, 2008 | 07:07 AM
HONDRETTI's Avatar
^ i dont see why not.
Old Dec 11, 2008 | 08:02 AM
JDM 98 GSR's Avatar
yeah you should be fine make sure you still get a tune though
Old Dec 12, 2008 | 08:40 AM
yes most definately, i would buy a honda s300 and install it before i even cranked that puppy up with a turbo.
Old Dec 12, 2008 | 08:41 AM
i'm wanting to get a turbo and stick with it, just see just HOW much power i can squeeze out of less than 10psi, but then again i image that can get Expensive.
Old Dec 12, 2008 | 09:11 AM
tweek_boii's Avatar
going all motor can be more expensive then turbo, i say save up and get your self a turbo kit, or make your own buying used parts and what not..
elusive123
Dec 30, 2005 11:16 PM
dungsta
Jan 24, 2005 08:22 PM
ras
Dec 16, 2003 06:42 PM
not133t
Oct 3, 2003 11:19 AM
Rratedcivichatch
28
Sep 23, 2002 07:28 PM
