noob question #2 ???????????????????????
if i wanted to resize my block as big as it can go, what would i ask the machinist to do, [its a LS motor] and what parts would i need to provide for him?
The price will be the same regardless, the sleeving process is removing the stock sleeves and installing the aftermarket sleeves. The sleeves are them bored to whatever bore is desired and then the final hone is performed to achieve the correct piston to wall clearance for your specific piston and build characteristics, i.e. naturally aspirated and forced induction motors will generally have different clearances.
what's your plan for the engine? if you just bore the block out without doing anything else you're going to end up spending a lot of $ for a small increase in power.
its got 224k on it, the valve cover gasket leaks, the timing belt tensioner is shot, hence the timing is off but the a/c blows cold...i pound the crap out of it and daily drive it about 60 miles a day. most will say swap it [ which i can do and have done on other projects ] but i rather rebuild it...i wanted to replace all the internals.[block and head]. FLAME AWAY!
i had a egsr hatch back in the day and to be honest VTEC dont really impress me...the way i see it if i bore the block and build the head it should be just as good as VTEC. than im ready for turbo or nos.
i aint trying for beat him...wait i am..hes the man to beat...so i want to do it with b series so i can call it a K Killer... hook me up with a good LS[B18B1] setup and i will do my best to build it...i want it N/A as much as possible....i dont like the problems that come along with F/I. tuning, traction, waiting for boost. i want to down it and take off like my GSR did...it would plant me in my chair until i let off the throttle...no pause between shifts and stuff like that...
Angel4768
Nov 21, 2011 08:21 PM
hoskos
Dec 12, 2005 08:08 PM
TypeR0149
Aug 22, 2001 12:32 AM
