Steering wheel removal
Old Dec 10, 2008 | 09:24 PM
niceprelude's Avatar
Default Steering wheel removal
How to remove the steering wheel for 92 civic?
Old Dec 10, 2008 | 09:39 PM
BlueIntegraBoy's Avatar
Unplug the negative terminal of the battery. Wait 10 minutes. Remove side panels of the steering wheel. Unplug SRS plug from airbag. Use T30 torx bit to remove the airbag screws. Remove airbag and unplug horn wire. Use a 19mm socket to loosen the steering wheel nut. Give the wheel a couple of quick jerks. Remove the nut, then remove wheel.
Old Dec 10, 2008 | 09:49 PM
would the airbag check light turn on,do i also disconnect the positive battery too,so i would have no air bag for safety,if i put a aftermaket wheel
Old Dec 10, 2008 | 10:52 PM
Just the negative terminal is fine. The SRS light will turn on if you put back the negative terminal with the airbag plug unplugged. Of course you will lose airbag safety if you put an aftermarket wheel.
Old Dec 10, 2008 | 10:54 PM
will i pass inspection
Old Dec 11, 2008 | 05:05 AM
1LowSol's Avatar
Depends on were you live
htwitr01
Jul 8, 2010 07:13 PM
spooneg8
Dec 18, 2006 12:58 AM
Jdmdc4ls
Apr 24, 2006 12:15 PM
civicb16
12
Nov 10, 2004 04:23 PM
UndergroundVR-4
Mar 22, 2003 09:57 AM
