vtec wiring question 92ls w/ a b17 swap
i checked the pin outs for both obd1 ls and obd1 b17 gsr.
the extra ones that the gsr has are:
a4: vtec spool solenoid valve
a20: purge control solenoid valve
d3: knock sensor
d6: vtec pressure switch
i know i wire 3 of them. a4, a20, and d3, what do i do with d6? and which wire do i have to ground?
i have a 92 gsr shell so can i just find the wires that run from the ecu to the pass. side where the harness connects to the engine harness right? LMK, im going to wire the vtec myself when i put the swap in and want to hit vtec when i swap. lol!. thanks guys! any help would be great!
d3: knock sensor
hey wats up man i just did a b17 swap on a 93 da gs and i just used the stock gs engine harness then i ran only three wires i ran the knock sensor to the d3 pin and then the two wires from the vtec solenoid i didnt even run into the purge solenoid i never ran into that wire
d3: knock sensor
d3: knock sensor
Just pick up a vtec subharness from Rywire, that's what I did. It comes with 4 wires, 3 are plugged into the ECU, the 4th one is not. It was $75, it's worth it just for that fact that you don't have to mickey mouse any wireing, the harness comes with all the plugs. Check it out on my build thread, it's towards the last few pages I believe.
But if you have the know how and all the plugs, making your own is totally an option.
