fs/ft eg fully built turbo,,5 lug championship white!!!!
the car is a 93 cx hatch,,painted championship hatch,the car was completly disassembled n strip to paint,engine bay, door jams, trunk jams, inside everything was painted,all new honda rubber installed when windows were put back..brand new motor, i have 182 pics of the whole assembly of the car when it was put together!!lots of extras VIN will be suplied to serious buyers.
if you need any more pics let me know and ill get them for you!
Exterior
-painted championship white
-fiber image carbon hood
-vis mugen carbon front lip
-vis mugen carbon sideskirts
-vis mugen carbon rear lip
-vis carbon duckbill
-vis carbon spoon replica mirrors
-carbon fiber gas lid
-jdm thin side moldings
-vision amber corners
-all new oem rubber
-jdm fenders with sidemarkers
-shaved antenna
-black housing headlights w city light
-10k hid kit hi n lo beam
-have the jdm amber fogs but wont fit the bumper
Interior/Electronics
-95 ex power window conversion
-05 rsx type s black leather seats
-jdm center console
-momo blk/red stitch steering wheel
-momo steering wheel hub
-jdm type r shift boot
-spoon shift ****.
-eclipse bad *** headunit
-audiobahn component front n rear speakers
-brand new black carpet
-fidanza short throw shifter
-civic ex cluster
-auto meter gauge pod
-aem wideband gauge
-aem boost controller gauge
-aem oil pressure gauge
-greddy turbo timer
-password jdm airbag delete
-got windows tinted 20%
Engine/Transmission
-95 ls full ls swap (tore apart n redone)
-je 9.1 pistons
-eagle rods
-cometic headgasket
-honda oem bearings
-honda oem oil pump
-honda oem timing belt
-honda oem water pump
-skunk 2 cam gears
-crower stage 2 turbo cams
-crower spring
-crower retainers
-ferrea stainless valves
-golden eagle block guard
-jg edelbrock intake manifold
-professional product 70mm throttle body
-aem fuel rail
-aem fuel pressure regulator
-b&m fuel pressure gauge
-hasport limited edition black street mounts
-competition stage 3 clutch
-competition lighten flywheel
-phantom grip lsd installed
-moroso oil pan
-moroso valve cover
-or the 1 thats on it which i like
-blox cam seal
-msd ignition coil
-ngk sparkplug wires
-fluidyne radiator
-slim fan
-550cc injectors
-lovefab mini me manifold
-garrett 60-1 turbo
-spearco intercooler
-tial 38mm wastegate
-3 inch downpipe
-3 inch greddy full catback exhaust
-walboro 255 fuel pump
-greddy catch can
car is tuned on chrome pro right now,, it has a very good tune on it its tuned on 15psi on pump gas,,its very conservative tune!!! the car has alot more to offer!!
Suspension/Wheels
-type r 5 lug conversion
-front drilled n slotted rotors
-front n rear calipers were proffesionally powder coated red
-ebc front n rear brake pads
-stailess steel brake lines
-gsr master cylinder n si poportion valve
-skunk 2 front camber kit
-skunk 2 rear camber kit
-skunk 2 rear lca's
-skunk 2 lower tie bar
-nrg carbon rear upper strut bar
-nrg carbon front upper strut bar
-arp extended studs
-new ball joint
-kyb front n rear struts
-neuspeed race springs
-spoon sw388 16" wheels
-faken azenis tires
-skunk 2 lug nuts
the car is in perfect shape no dents or scratches,runs great very very strong,it just spins it really needs a good set of tires! the car has more things ill post it up when i think of them.
im askin 12k obo
im willing to do some trading on a rsx-s or something newer. .
thanks for looking!!
Exterior
-all new oem rubber
-shaved antenna
-jdm center console
-spoon shift ****.
-civic ex cluster
-aem wideband gauge
-greddy turbo timer
Engine/Transmission
-je 9.1 pistons
-eagle rods
-cometic headgasket
-honda oem bearings
-honda oem oil pump
-skunk 2 cam gears
-crower spring
-crower retainers
-aem fuel rail
-moroso oil pan
-moroso valve cover
-blox cam seal
-msd ignition coil
-fluidyne radiator
-slim fan
-550cc injectors
-garrett 60-1 turbo
-3 inch downpipe
-greddy catch can
Suspension/Wheels
-skunk 2 rear lca's
-arp extended studs
-new ball joint
-faken azenis tires
-skunk 2 lug nuts
im askin 12k obo
