PW and PM Quick Question
Old Dec 10, 2008 | 05:24 PM
Headman's Avatar
Default PW and PM Quick Question
Hey Guys
Quick question for all you experiance Honda Techs. Do any of you know if the Honda Civic 92 - 95 model DX namely are all prewired for the power windows and power mirror and such. or is this something that has to be wired in. I Know like in Chevy and Fords most of the power option are wired in weather you have the option or not so all you have to do is plug in play so to speak. Just wonder if anyone knows before I have to pull apart and check ?? Thanks guys.
Old Dec 10, 2008 | 05:46 PM
91blackEF's Avatar
im not sure if they are pre ran on not but the place to check would be behind the drivers door panel that would be the main set of wires but when i went to the junkyard to find a new window regulator i dont recall seeing any wires in the manual doors
Old Dec 10, 2008 | 05:48 PM
cehcivic15's Avatar
no there is not
94EG8's Avatar
Seagull Management
They aren't prewired, if its coupe or sedan I suggest you get the entire interior harness from an EX. if you have a coupe, use a coupe harness, sedan sedan. if its a hatchback you'll have to use an EX coupe harness and remove the wiring you need and integrate it into your harness.
Edit, forgot to add, be sure to grab the door harnesses as well.
Old Dec 10, 2008 | 09:24 PM
Headman's Avatar
Thanks for the help gentlemen, I will see if I can find a ex harness at the local pull apart.
Old Dec 10, 2008 | 11:29 PM
wangkata's Avatar
x2 I used ex harness on my 93 hatch....
diegom1990
Oct 22, 2012 06:47 AM
moosepoop21
Nov 13, 2008 08:42 AM
EvoMperor
11
Apr 22, 2008 03:05 PM
PreludeH22vtec
Sep 28, 2005 11:20 AM
Outrun
Aug 25, 2005 12:29 PM
