Civic Hatchback Inside Brake Lights? (EG/EH)
Old Dec 10, 2008 | 09:51 AM
I Like Hondas's Avatar
Default Civic Hatchback Inside Brake Lights? (EG/EH)
Hello all!
I was looking on another site and I came across a DIY on installing inside brake lights on Civic hatch's. Here's the link if you don't know what I'm talking about. http://civic-eg.com/viewtopic.php?t=1465
I really wanted to do this because I will be getting a duckbill shortly without a third brake light. So I figure any other extra brake lights would help.
Well, I went out to my car to see where everything was and see how much work it would be, and I found existing bulbs in that spot. I had someone press the brakes to see if they let up or did anything and they didn't. The bulbs don't look blown either. So now I'm wondering, instead of adding more ghetto wire and what not is there a way that I can just get those existing bulbs to work? Here are some pictures so you know what I mean. If I'm leaving any vital information out just let me know. Thanks for any help!
Old Dec 10, 2008 | 10:00 AM
shaggsdb's Avatar
those lights are running lights. they are supposed to light up when you turn the lights on. i dont know if its possible to splice them into the brake lights. i would use quick splice connectors to make it a little cleaner looking and you wouldnt have to cut and splice and wires(more reliable in my opinion)
Old Dec 10, 2008 | 10:33 AM
Oh ok that makes sense they're running lights. Now, I'm pretty sure on the coupes and sedans that they do light up for the brakes as well. Maybe I could get a harness or bulb off a coupe to make it work..
I'm not familiar with quick splice connectors, how do they work?
Old Dec 10, 2008 | 12:43 PM
94EG8's Avatar
Seagull Management
I would use quick splice connectors to make it a little cleaner looking and you wouldnt have to cut and splice and wires(more reliable in my opinion)
Quick splices/Scotch locks are the most useless unreliable piece of **** I ever had the displeasure of working with. They cut halfway through the wire severly weakening it, often times the wire will break off unless its in an enviroment where it wont get disturbed. Maybe i'm a little biased because I live in an area where we use a ton of salt on the roads, scotch locks turn green inside and the wire literally rots off in a matter of months. Solder and shrink tubing is where its at if you want something to last, if you can't solder at least use perma-seal butt connectors that come with shrink tubing on them.
Old Dec 10, 2008 | 02:22 PM
^Wow, thanks for the warning. I'm thinking if I had to add any wiring I will be soldering.
But, does anyone know if the inner light on the coupes and sedans light up for the brakes???
Old Dec 10, 2008 | 02:27 PM
wrenchez81's Avatar
i tell that bulb is blown from here!!! they should be either 194 or 921 bulbs... change them both...
Old Dec 10, 2008 | 02:30 PM
turboteg90's Avatar
pm for noodz
cant see the thread on the link homie
Old Dec 10, 2008 | 02:34 PM
94EG8's Avatar
Seagull Management
Yeah they do.
Old Dec 10, 2008 | 02:52 PM
Weird, it works for me. Maybe you have to be a member. What does it say when you click the link?
Originally Posted by 94EG8
Yeah they do.
I wonder then, if I could just use the set up they use. Or for that matter what exactly is different between the two.
Old Dec 10, 2008 | 03:18 PM
BryanM.'s Avatar
Resident Gearhead
It says: Please enter your username and password to log in.
Sucks, I wanted to see that link too.
Old Dec 10, 2008 | 03:26 PM
sageuvagony's Avatar
Yes. I have a Sedan and all 4 lights (both inner, both outer) light up when I press on the brake.
Yep, I learned this as well. I had tapped into the tach wire on the distributor with those quick splice thingies to connect it to my "remote start" module. It worked well for about 3 years but eventually the tap was no longer good. The wires had become very frail and was all oxidized because the splices had cut pretty deep into them. I was using the correct size splicer thingy too.
Old Dec 10, 2008 | 03:37 PM
94EG8's Avatar
Seagull Management
Heres another link to a different, or possibly the same write up. http://civic-eg.com/viewtopic.php?t=1465
Old Dec 10, 2008 | 03:40 PM
BryanM.'s Avatar
Resident Gearhead
Thanks
Old Dec 10, 2008 | 11:49 PM
Yeah thats the one. I'll switch the link in the original post.
Old Dec 10, 2008 | 11:51 PM
So I'm thinking the cleaner and better way to do this and keep the running lights, would be to somehow use the harness or set-up off a coupe or sedan.
I'll ask again, does anyone know the difference?
Old Apr 29, 2012 | 03:13 PM
g35silversurfer's Avatar
Default Re: Civic Hatchback Inside Brake Lights? (EG/EH)
here:
https://honda-tech.com/forums/showth...8#post47266098
Old Apr 30, 2012 | 12:59 PM
yimmycr's Avatar
if you put a brake light in the inside, have a problem for the head, put a led bulbs to be safe
BLOCK8732
Sep 9, 2014 05:19 PM
Jccrew
Honda CR-V & Element
Mar 13, 2014 06:24 AM
JDM_rolex
Lighting
Jul 5, 2009 10:12 AM
IOSUA
Nov 20, 2007 11:08 AM
intekragsr
Jun 29, 2002 07:28 PM
