FS: AP2 04 f22C Engine and misc 06 s2000 engine parts
Hey Guys,
I have a 04 F22C blown, either the head gasket is gone or the block is cracked. I dont have the time or the patients to tear down so im selling it.
I purchased a 06 F22C So I have a bunch of parts off of that too.
Purchasing?: Will take reasonable offers, prices in US dollar.
Calgary, Canada
Motor info:
Was in good running order. What happened was the water pump came loose, and leaked out water. It over heated, then the owner poured cold water into it.. which makes me think it broke the block, but I'm not sure unless I tear down the motor. Motor runs great if theres no coolant, but it will flood and hydro lock if you add fluid. The Head should be mint.
The motor is in long block form, no manifolds. It does have water pump on it still, and pulleys(crank, and water pump). Includes 06 f22C Valve cover, its completely different than the 04 f22c valve cover, it will include 06 SENSOR WHEELS for the cam, if you want to use an 06 HARNESS.
Stamped 03 on the back.
motor has about 70,000km's
looking to get $300.00 + shipping for the motor, I will ship it for 300.00 US to United states.
Engine mount plates $50
06 AP2 Spark plug cover has some corrosion on it, paint it or powder coat it: $70.00
04 Tensioner: $70.00
06 Fuel Rail Cover (only works on 06 Manifold): $30.00
06 ENGINE HARNESS, for drive by wire throttle, like new: $250.00
06 Coil Packs, not sure if there different than 03 but 40,000k on them: $150.00
06 Drive by wire, Electronic Throttle Body with sensors: $250
06 Intake Manifold for drive by wire, includes 4 injectors, fuel rail: $350
If you buy the manifold, you may need most of the above parts, or you can custom something up.
Contact me at ck231@shaw.ca or by pm.
Calgary, Canada
Motor info:
Frankie92481
Jul 30, 2005 12:49 PM
RenoRacing
Oct 28, 2002 04:52 AM
