99-00 foglights with parking light
Old Dec 9, 2008 | 10:45 PM
magicguy's Avatar
Default 99-00 foglights with parking light
I have this weird thing happened last night, I've followed HT to wire the foglights to parking light back in 3 years ago. It was in perfect working order until yesterday.
Whenever I un-alarming my car, Dash board + Cluster + Fogs will flash.
For some reason, when I sit in the car and turn the light switch by one click. No Fogs nor cluster are lighting up. I checked all the fuse, they seem perfectly fine.
so...they only flash when I alarm and un-alarm the car, will not work when I turn the light switch 1 click or 2 clicks..
Any Ideas from HT bros would be appreciated.
Old Dec 9, 2008 | 10:50 PM
92 CIVIC 4DR's Avatar
mayby you have a wire cut somewhere and its so cold water is gettin into it
Old Dec 9, 2008 | 11:04 PM
magicguy's Avatar
so, I have to search for a wirecut from the whole floor harness eh?
Old Dec 10, 2008 | 06:28 AM
magicguy's Avatar
up
Old Dec 10, 2008 | 06:37 AM
stock ek's Avatar
just dbl check the wiring on the fogs, make sure that theres not a wire groundingout somewhere
Old Dec 10, 2008 | 07:10 AM
escape317's Avatar
it sounds like ignition light relay maybe wen the alarm was installed the pos of the dash was added an extra relay you should check em out
zsudz922
Sep 25, 2009 08:25 AM
ej8slim
Mar 20, 2006 03:59 PM
dungsta
May 17, 2005 01:43 PM
dungsta
May 15, 2005 01:57 PM
paeaknoy
Nov 7, 2003 03:56 AM
