Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 accord not starting HELP
Old Dec 9, 2008 | 06:50 PM
cindysi's Avatar
Default 03 accord not starting HELP
Delete
Old Dec 9, 2008 | 07:41 PM
redbull-1's Avatar
Have the timing checked.
If the timing is okay, then have the compression checked.
Old Dec 9, 2008 | 11:19 PM
cindysi's Avatar
Timing and compression is perfect. Do you need to reset the computer after the valve adjustment?
Old Dec 10, 2008 | 05:19 PM
HONDAPARTSMANMIKE's Avatar
first off the valve adjustment was done wrong. exhaust valves are ussualy a biger gap than the exhaust.
did you chk for a restriction in the air box.
does the car have a mass air flow sensor
Old Dec 10, 2008 | 05:28 PM
tortuga89's Avatar
^ yep he is right re check then let us know
Old Dec 10, 2008 | 06:54 PM
cindysi's Avatar
Ok I redid the valves then put everything back and I had to put antifreeze in the hose under the throttle body and it started right up!!! Thanks for the help and Im going to get my damn money back from the idiot who said they were the same
Wesleycrx
Dec 7, 2014 10:24 AM
1FAMOUSDB8
Apr 30, 2012 03:38 PM
Layziejoe775
Aug 26, 2006 03:54 PM
shbrown
May 28, 2005 01:00 AM
