Balance Shaft and Front main seal
Old Dec 9, 2008 | 02:53 PM
kornerk12's Avatar
Default Balance Shaft and Front main seal
Ok well I installed them however, they arent 100% straight. One side is flush if not slightly slightly in and the other side is in a slight bit more. Basically my question is, do they have to be DEAD straight ? I know to a certain extent it will leak however i dont want to worry over something very small.
Old Dec 9, 2008 | 03:56 PM
1grex's Avatar
I think you'll be aiiit
Old Dec 10, 2008 | 05:13 AM
jweller's Avatar
If you're doing the job, do it right, get them set flush, and not cocked in the hole.
Old Dec 10, 2008 | 05:30 AM
Duane_in_Japan's Avatar
You can use a flat round punch and tap on the area (near the outer edge of the seal of course) that is sticking outward the most, you may want to use a large socket to push it in but sometimes that is a bit difficult to make straight.
Old Dec 10, 2008 | 07:41 AM
kornerk12's Avatar
yea i was using a socket and its not in there perfect. A punch is a good idea, what about the areas that are in alittle bit further than flush, i was hesitant to pull then out with the pick set, scared that i would damage the seal.
lolv8s
Apr 16, 2016 10:36 PM
kenzo42
Sep 12, 2014 10:01 PM
V-8 who
Mar 8, 2009 09:23 AM
95hbMatt
Apr 13, 2003 09:09 PM
Boostless97Lude
Jan 27, 2003 03:01 AM
