1993 civic cranks but won't start!
Old Dec 9, 2008 | 01:50 PM
PreludePeterr's Avatar
Default 1993 civic cranks but won't start!
at first, i thought it couldve been my fuel pump but everythings fine. it turns on, motor cranks but sounds as if it has no gas. i then hear a clicking sound coming from the fuse box under the dash. what can this be? if anyone can help, i'd appreciate it. thanks in advance
Old Dec 9, 2008 | 01:59 PM
zkdawg's Avatar
turn the ignition to the on position and listen for a humming noise coming from the rear of the car. if u cant here it then take a rubber mallet and hit your fuel tank a few times. if that dont work, check for spark. if u have spark then check the relays in the fuse box and make sure they work.
Old Dec 9, 2008 | 03:11 PM
Unseen Racer's Avatar
MY FREAKING CAR DID THE SAME THING ON SUNDAY NIGHT ON THE DRIVE HOME!
i was driving home and at a stop sign some guy wanted to race. so we took off and about 20 feet from the stop sign my car died!
3 hours later a tow truck came and towed my car home.
i checked the fuel pump, made sure the spark plugs were tight, spark plug wires were connect right etc.
it was NONE of that.
then i thought "HMMM.... ignition coil". i checked it. that mess was blown. didnt work.
went to autozone, bought a new one and now it starts like a beauty!
its your ignition coil
Old Dec 9, 2008 | 03:34 PM
jdmjohnyyy's Avatar
wow! i never herd of hitting your gas tank...
check under your dash, there should be a gray relay by your left foot
i replaced that and my car ran fine.
Old Dec 9, 2008 | 04:03 PM
iamthefollower's Avatar
yeah the one beside your left foot is the main relay.. it sounds to be that the coil isn't firing.. it would be best to see if your getting spark before buying parts and if your not just change the coil.. as unseen racer said.. my car also did the same thing over the weekend lol...
Old Dec 9, 2008 | 06:52 PM
what are you talking about? i checked the ignition coil to see if it was firing.
Old Dec 9, 2008 | 07:30 PM
wow, this appears to be a recent common problem haha. i will check for spark to make sure its not the ignition coil and then move ahead on to the main relay. thanks fellas
Old Dec 9, 2008 | 07:38 PM
Ok ?, why are you getting upset for someone agreeing with you?? read the post again, I was talking to the OP.. I was also telling him to check the coil... as i said.. like Unseen Racer said before.. but then I was also saying that mine had also done this over the weekend.. read and check before posting, instead of arguing with someone for agreeing with u.
Old Dec 9, 2008 | 09:01 PM
T3KNiQe's Avatar
If its the main relay you wont hear the fuel pump prime when you turn the ignition on...If you do hear the fuel pump prime then the main relay is ok.
But main relays that are bad can work when they want to, and suddenly not work. I had a problem like that with a old DA, somtimes it wouldn't start, and sometimes it would. I did a lot of research and ruled everything out. Ended up it was a faulty main relay, and honda had changed the part number from RZ-0063 to RZ-0067.
Spray starting fluid in the intake and try and start the car, if it runs for a second and dies then fuel isn't getin were its supposed to be.
pmey
May 26, 2009 01:11 PM
slowassciv33
10
Jul 1, 2007 04:04 PM
manonamission
Dec 2, 2005 04:57 AM
vietjdmboi
Mar 8, 2005 06:33 PM
civic702
14
Jan 15, 2005 05:11 PM
