1997 integra swap, rear disc conversion, fidanza,brembo,gsr trans,d-series swap!!!!!!
-1997 Ls Swap, Comes complete. The motor is a B18B1 which came out of a completely stock Integra. Milage on the motor is 84,xxx miles. The motor has no issues and has been well maintained and taken care of. Car has clean vins and is a legit motor.
What will be included in the swap-
-Complete long block and transmission with ac bracket,ac compressor,power steering pump and bracket,alternator,intake manifold,distributor,sensors,o2 sensor, starter, wiring harness,etc. Basically how it came out of the car.
-All motor mounts and brackets out of the integra
-Ls integra shiftlinkage and shifter
-Stock ecu out of the integra
-Wiring harness
-transmission(went ahead and got the flywheel resurfaced,just installed a new honda oem throwout bearing, and a newer oem clutch that i had sitting around with 5,000 miles on it.)
-Axels, Axels were bought by me from Napa auto parts store. They are "new axels", and have about 4,000 miles on them.
Asking price for the swap is 1400obo, considering all oem parts that have been put into the motor.No trades, just cash.
Or you can make offer if you want the longblock,transmission,wiring harness,etc....
-Also have a 98 gsr transmission,will include new throw out bearing, resurfaced stock flywheel,speed sensor, stock clutch and disk,still very good condition. $600obo
-Rear disc brake conversion from a 1997 integra, comes with e-brake cables, lower control arms,rotors,calipers, rear sway bar.- $220obo
-Brembo rear drilled rotors that will fit a 94-2001 integra, they had a couple thousand miles on them,i had the machine shop turn them, they are fresh and ready to go. $120obo
-Koyo radiator full size,fits 94 up integra, no leaks or problems,very good condition-$325obo
-750cc injectors, they were on my friends gsr turbo integra, He said he bought them from DNR, they have about 6,xxx miles, $250obo
-Fidanza fylwheel,will fit any b-series engine, has about 3,xxx miles on it $140obo
-Half size radiator that came out of my 92 civic hatchback,i bought it brand new a year ago.... $50 firm
-D-series stock and original motor out of my 92 civic hatchback cx, d15b ,it has 135,xxx miles,comes complete with trans and wiring ,ecu, axels,mounts,etc. i replaced the clut at 130,xxx miles and resurfaced the flywheel. $550 obo
If you have any questions or interested, give me a called at 707-372-3102. NO PM's PLEASE!
-Wiring harness
Dasfinc
37
Mar 5, 2008 11:59 AM
