Honda S2000 Honda S2000
s2000 camber kit ??
Old Dec 9, 2008 | 10:42 AM
edd's Avatar
edd
Default s2000 camber kit ??
i have a 2000 s2000 and wondering what is a good camber kit to buy.??
your opion is appricaited.
Old Dec 9, 2008 | 10:45 AM
Chris.'s Avatar
Honda-Tech Order of Merit
you dont need a camber kit. you can adjust the camber on the s2000 without one
Old Dec 9, 2008 | 12:01 PM
Black S2K's Avatar
this sint a civic
Old Dec 9, 2008 | 12:56 PM
hotcivicsi's Avatar
you can only adjust it so much....when I had my coilovers I was running -3.5 on the rear and that was maxed out. On my skunk2's i think im still -3 or-2.5 which I believe is still more then stock. So in some cases a camber kit is required. I dont think there are to many options I know Eibach makes a kit, but I know if you buy a kit you have to run 17" wheels or bigger
Old Dec 9, 2008 | 12:59 PM
Chris.'s Avatar
ive seen guys running 5 degrees of camber on their stock setups with just coilovers, so i dont see why you would need a camber kit then.
im currently running 3.5 degrees in the rear, and the shop that did my allignment said that they could have gone another 1-1.5 degrees
Old Dec 9, 2008 | 01:00 PM
papa5murf's Avatar
Originally Posted by hotcivicsi
you can only adjust it so much....when I had my coilovers I was running -3.5 on the rear and that was maxed out. On my skunk2's i think im still -3 or-2.5 which I believe is still more then stock. So in some cases a camber kit is required. I dont think there are to many options but I know if you buy a kit you have to run 17" wheels or bigger
There is no need for a camber kit. There is no need for one to go back to OEM specs. Most people that lower their cars properly are doing so with performance in mind and with that in mind, they want to run more camber as it is.
Buying a set of camber kits is a complete waste of money.
And you should take your car to a better alignment place, because there is no reason why you have to be running -3.5 on Skunk2 springs. And -2.5 is what many people run who are slammed.
Old Dec 9, 2008 | 01:44 PM
HondaKyle's Avatar
/thread
Old Dec 10, 2008 | 03:55 AM
rice4life's Avatar
-SPC makes caber kit for s2k
the problem with stock camber adjustment in the front is that the more negative camber you use, you reduce caster. so i'm going to use this kit to keep max caster and still be able to get -3 deg camber that i need for track.
http://cgi.ebay.com/ebaymotors/SPC-H...QQcmdZViewItem
Old Dec 10, 2008 | 05:55 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
this is true, but it doesnt reduce it that much...
Old Dec 10, 2008 | 06:26 AM
Black S2K's Avatar
track? down hill is more fun
lol jk its a quote from the intial d movie
Old Dec 10, 2008 | 06:42 AM
HondaKyle's Avatar
Originally Posted by black s2k
track? Down hill is more fun
ahhhhhh!!!! Hahaha
nikboca
Honda S2000
Apr 11, 2006 09:22 AM
ITR_1211
Honda S2000
Apr 14, 2005 01:15 PM
fluxcapacitor3000
Mar 2, 2005 11:25 AM
manson
Apr 23, 2004 09:44 AM
PnX-R
Apr 28, 2002 03:37 PM
