Honda S2000 Honda S2000
Camber Kit
Old Apr 11, 2006 | 09:16 AM
nikboca's Avatar
Default Camber Kit
I just lowered my car an inch all around. The rear wheels lean in towards the top of the fender just a little bit. Do I need a camber kit for this or is ok just leaning a little.
Also I was wondering what is the range of offset that will fit on an s2000. 40-50, 35-50?
Old Apr 11, 2006 | 09:22 AM
evil vapor's Avatar
Default Re: Camber Kit (nikboca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikboca &raquo;</TD></TR><TR><TD CLASS="quote">I just lowered my car an inch all around. The rear wheels lean in towards the top of the fender just a little bit. Do I need a camber kit for this or is ok just leaning a little.
Also I was wondering what is the range of offset that will fit on an s2000. 40-50, 35-50?</TD></TR></TABLE>
This car has camber adjustment, take it to an alignment shop and they can align it. No need for a camber kit. Having some negative camber doens't hurt but your toe needs adjustment after lowering.
Depending on width of the wheel, you don't want to run anything lower than 48mm front and 50mm rear.
jmai86
Jun 4, 2008 08:38 AM
b16ferio
Honda S2000
11
May 5, 2008 11:30 AM
stock99si
Jul 16, 2007 09:07 AM
KiNG $h!t
Suspension & Brakes
Mar 7, 2005 10:52 AM
96 SOHC VTEC
Jan 5, 2003 04:34 PM
