4ws and abs removal
Old Dec 9, 2008 | 08:18 AM
prelude-all-the-way's Avatar
Default 4ws and abs removal
I have a 92 si 4ws model and I am shaving and tucking the engine bay right now. I looped the power steering lines and I was wondering could I get rid of abs and 4ws while still maintaining a drivable car?
thanks rob
Old Dec 9, 2008 | 08:19 AM
Acidcrakker's Avatar
You need to convert to the manuel brake booster. You can get one off a 4th Gen 92 S model I believe. I think stainless steel brakes lines are needed as well
Old Dec 9, 2008 | 08:30 AM
Prudz_lude's Avatar
according to md23vtec you don't need a prelude s brake booster. He used his Si booster when he deleted his abs. Just use a prelude s prop valve and brake master cylinder.
Old Dec 9, 2008 | 08:32 AM
kulrevon's Avatar
to get rid of the 4ws I believe you need a new rear sub frame.
Old Dec 9, 2008 | 08:59 AM
ok so a master cylinder/booster and a prop valve? what about the lines that go into the wheel well? and 4ws i just take out and put in any subframe non-4ws?
Old Dec 9, 2008 | 09:46 AM
kulrevon's Avatar
theres other parts I am sure you need. like the toe arms and such.
Check out the honda parts catolog and compare both models.
Old Dec 9, 2008 | 09:55 AM
jlude90's Avatar
the soft lines are the same, but the hard lines are different
Old Dec 9, 2008 | 10:05 AM
Do you have a thread on where this conversation took place?
Old Dec 9, 2008 | 10:27 AM
thats a little extreme i thought it was master cylinder, brake booster, brake bracket, prop valve and hard lines? i need some help cuz im gonna try to attempt this
Old Dec 9, 2008 | 10:29 AM
Prudz_lude's Avatar
It is on preludepower in md's thread, check it out.
Old Dec 9, 2008 | 11:13 AM
kulrevon's Avatar
You need the toe arms and the very rear subframe if you are switching out the 4ws. possibly more. go look at the parts differences on majestic honda.
number 4 is for 4ws and number 5 is for the si.
And on the other picture your car doesn't have arms 24/27. your car has the 4ws box in its place.
red-si-eg..
Jul 23, 2008 07:43 AM
GoldLudeRay
Jul 20, 2008 06:02 PM
sleespeed
Mar 9, 2008 04:09 PM
integrax97
May 3, 2007 12:15 PM
