1995 integra LS to b20 SWAP
Old Dec 8, 2008 | 06:23 PM
NLFer's Avatar
Default 1995 integra LS to b20 SWAP
would i need to replace any wiring harness or anything to do this kinda of swap if i do i think i'm just gonna stay with the stock one
Old Dec 8, 2008 | 06:28 PM
weavertime1's Avatar
I did this a few years ago, and yes it is better if you basically strip down the B20 to the block and head and use everything from the Ls, like the intake manifold, dizzy, harness, etc. You can also use the ls (P75) ecu although I think it may burn a little lean...I believe however that minus the high intake manifold that some B20s have you can just use whats on the B20 unless of course you get a JDM one in which case would have the RHD harness on it which WILL NOT WORK. Good luck with whichever route you choose!
Old Dec 8, 2008 | 06:48 PM
petwhookie's Avatar
search
Old Dec 8, 2008 | 06:49 PM
2ndchirp's Avatar
I agree ^^^^... and please tell me its a B20Z.. personally i would not but a b20 in my integra unless its a B20Z cuz LS pulls harder than the other B20's
Old Dec 9, 2008 | 03:35 AM
NLFer's Avatar
really so you think i should just stick with the ls motor .......and i kinda figured i had to transfer over those things but i meant the whole computer harness from the car
thanks
Old Dec 9, 2008 | 03:51 AM
No changing the whole firewall harness. IMO doing the other things takes a little time, but the finished product is much better. What engine is it? Good luck!
Old Dec 9, 2008 | 03:25 PM
petwhookie's Avatar
http://www.b20vtec.com/forums/b-seri...faq-guide.html
great info for the misconception of b20b and b20z
Old Dec 9, 2008 | 06:19 PM
NLFer's Avatar
ok so you guys led me to go stcok but i was wondering if there's a difference between the b18b and the b18b1
Old Jan 8, 2009 | 10:17 PM
b18c1ej8's Avatar
Default Re: 1995 integra LS to b20 SWAP
i dont recall any differences, and btw im doing the same swap you are
Old Jan 9, 2009 | 02:01 AM
EJ1 LS guy's Avatar
um yeah I think a stock Ls(B18b1) puts out about 142 hp.....and the B20b puts out about 126 hp......and the b20z puts out about 146 hp.......so unless you have a b20z there's no point in a swap unless you have to.......
B18b=JDM
B18b1= USDM
not 100% sure on any of this......just tryna help....
Old Aug 11, 2013 | 10:34 AM
Ej8_Santos's Avatar
I think the jdm 99-00 b20b is high compression. Pre 99 b20b is the 126hp one
Old Mar 11, 2019 | 08:40 AM
dlihc_dliw's Avatar
Icon5 Re: 1995 integra LS to b20 SWAP
what do u do if it is a jdm one with the rhd?
Old Mar 14, 2019 | 10:06 PM
egsleepercivic's Avatar
I did a JDM high comp b20 in my 95 LS, nice little upgrade, from my research the B20bs with knock sensor are high comp
I swapped the manifold and all the accessories over, plug and play, I also used the LS crank pulley, its smaller and the mount that bolts to the block on the drivers side, they were different
bettsbanger
Sep 19, 2009 12:09 PM
REDekSI
Aug 16, 2007 04:39 PM
ABCVTEC
Jan 31, 2007 08:45 PM
redDAinteg
Oct 18, 2006 10:29 AM
ComptonsF1NEST
May 22, 2006 07:22 PM
