p28 computer
Old Dec 8, 2008 | 11:16 AM
Ls_Turboteg's Avatar
Default p28 computer
Will a p28 run in my 95 Ls non-vtec? Which would be better stick w/ the stock or go with the p28?
Old Dec 8, 2008 | 11:40 AM
iH8RICERZ's Avatar
whats the point of switching to a p28 on your LS? A sohc vtec ecu will not run properly on your car....the only time running a p28 on your car is if you have vtec and the p28 is chipped and tuned. Stick with your stock ecu unless your motor is built
Old Dec 8, 2008 | 11:45 AM
okay, its just some dude wanted to trade me and said that it would work fine on my car and i just wanted to be sure i was right that it wouldnt work on my car thanks.
Old Dec 8, 2008 | 12:12 PM
pmey's Avatar
It's not gonna run right on ur car, unless the p28 is chipped for a Ls with basic spec for ur car, other den that if ur car is obd2 u still need a conversion harrness
"but i do like my chipped p28, im running it on my b20v and tell you what it's great just get it tune"
Old Dec 8, 2008 | 12:19 PM
weavertime1's Avatar
You just made things worse by saying that...
Old Dec 8, 2008 | 02:05 PM
pmey's Avatar
sorry ;-)
Old Dec 8, 2008 | 04:31 PM
and he already said his teg was a '95 therefore making it an OBD1 car...
Old Dec 8, 2008 | 06:45 PM
2ndchirp's Avatar
When i had my 94 LS i put a p28 in it and it ran rich and a slighter higher redline...almost 75 grand...but you should chip it.. it will make a big difference..its what i did and the Ls runs strong..
Old Dec 8, 2008 | 06:49 PM
Why would you put a P28 in a car running a B18B1? If it ran rich it would actualy have less power, and you would have a cel for vtec solenoid and pressure switch. Also its not real smart to run the B18B1 to anything above the factory limited 7000 rpms due to weak rod bolts. Addistionally "chipping" your car will not make a big difference if any difference at all, especially if everything is stock.
Old Dec 8, 2008 | 07:01 PM
2ndchirp's Avatar
Aint no point of getting the computer chipped if your "Completly stock"..When i did get a chip in my ecu my engine was not completly stock... and yes it did make a difference... just full exhaust and skunk2 manifold... a p72 with a chip programed for a B18b..and no check engine light on for the vtec solenoid.. the chip took off some limitations and the engine takes full advantage of the manifold and exhaust ..i personally felt a noticeble difference from chippin the ecu...and no i did not say a p28 on a stock LS will give you power..only reason i put it on my LS was to try it out long time ago as a begginer to this honda stuff..
Old Dec 8, 2008 | 07:25 PM
I know that it wont change much and im not looking to invest anymore money in my teg its just a guy wants to trade and my car isnt stock i was just trying to figure out if i should do it and i figured i shouldnt and i was right...
Old Dec 8, 2008 | 08:35 PM
biggoofy's Avatar
7000rpm ha i have a 9200 rpm redline and p28 chipped is great tune tune tune
Old Dec 9, 2008 | 03:08 AM
What are you even talking about? You're running a stock ls to 9200 on a P28 chipped? You have no idea what you are talking about, or you just don't know how to properly explain what you have. There is no way a stock ls would last in that range of rpms, and why would you run a P28 on it? Maybe just explain yourself a little better!
Old Dec 9, 2008 | 06:24 PM
2ndchirp's Avatar
Wow ... wat engine is that? it cant be an LS with stock internals..
Old Dec 10, 2008 | 06:40 PM
FULLYBUILT2.0's Avatar
should be fine...you might even get a 15hp gain!
Old Dec 10, 2008 | 07:10 PM
Do you have any facts supporting this statement?
HondaVTEC1993
Engine Management and Tuning
19
Apr 26, 2018 09:02 PM
Thump_eg94
Jun 25, 2010 12:37 PM
ej1project
Jun 15, 2010 07:30 PM
ThatsMyEG
Nov 22, 2005 07:48 PM
khang77642
Sep 3, 2002 06:06 PM
