Balance Proble
Old Aug 2, 2002 | 01:15 PM
TheHater
Guest
Posts: n/a
Default Balance Proble
All right I rebalanced my wheels ......same thing. Allright my car on the highway at 65 bounces like sh#@. over that is fine and if my steering wheel is pointed straight it goes slightly to the left and my steering wheel twitches a little. Please help.
Old Aug 2, 2002 | 01:20 PM
Si's Avatar
Si
Default Re: Balance Proble (BOOSTINSI)
Have your alignment checked, other than that, there might be something wrong with your suspension.
Old Aug 2, 2002 | 02:13 PM
TheHater
Guest
Posts: n/a
Default Re: Balance Proble (RedSi99)
ttt
Old Aug 2, 2002 | 02:15 PM
migs's Avatar
Where did you get your wheels balanced at? Is your tire PSI fine?
Old Aug 2, 2002 | 02:44 PM
96HatchB18's Avatar
Get the alignment checked......
After this if it still shakes you probably arent centering the wheels when you install them....The easiest fix for this is to get hub centric rings, but they arent 100% necessary if you put them on by hand and tighten them a little at a time in a star pattern.
But Since the car is pulling, alignment is proabably the culprit.
Old Aug 2, 2002 | 04:03 PM
deepnite's Avatar
Default Re: Balance Proble (96HatchB18)
hub ring will cure the problem..if u got wheels at america s tires..they ll have the rings for ya free..if not they ll get them for u
///Nick
Suspension & Brakes
15
Nov 28, 2011 10:49 AM
audsyn
Jul 30, 2009 02:57 PM
cocoluco
Suspension & Brakes
11
Mar 11, 2009 10:03 PM
namax
Jul 16, 2007 04:12 PM
derelikt
15
Feb 21, 2002 12:35 PM
