somebody help me with this please
i have a 95 d16z6 with 190000 miles on it, it runs pretty good but i really want to boost it and i dont know what i should do first like if i should build the motor up to take it or do a swap
go out and buy a turbo kit boost it for like 10 miles blow it up and buy a B series...
190000 i mean come on that engine can only take so much... either rebuild the D series or spend the $$ on a low mileage B series and boost that if you want.
if it doesn't burn alot of oil boost it. Milage doesn't mean ****. The more stock motor is worn on cylinders walls the better your chances are that it's not going to blow up (you need bigger piston to wall clearances). Just do it right and it should last. If not you can get another single cam for $400 with trans.
luvmihatch
16
Aug 10, 2008 03:30 PM
