Distributor Shaft seal
Old Dec 8, 2008 | 07:43 AM
04silvep3's Avatar
Default Distributor Shaft seal
ok my dizzys leaking from the inside of the cap iv replaced all outside shaft seals is there an inside shaft seal behind the signition coil on the houseing?
Old Dec 8, 2008 | 08:03 AM
siregcivic's Avatar
you can replace the seal, ill ask my friend how he did it, but nobody caries the seal its special order, you have to take the whole internals of your distributor apart to get to the seal, then pry it out without breaking it so you can replace it, honda says you have to buy a whole new distributor
Old Dec 8, 2008 | 08:21 AM
honda.lioness's Avatar
All of the above is dead on correct. To be a bit more exact, it would be a new distributor housing one would have to buy to get the new oil seal. Depending on the year, a new OEM housing may run only about $100 through OEM online parts dealers like www.bkhondaparts.com . The oil seal is shown below:
The following sites had the seal in mid-2008:
http://www.bestautojobs.com/shop/ignitionbesthonda http://market.autopartsfair.com/honda-engine_parts
Clues on removing the seal appear in the writeup at http://honda.lioness.googlepages.com/distributorbearing
Old Dec 8, 2008 | 10:54 AM
04silvep3's Avatar
bump
Vtec_India
Feb 15, 2016 10:15 PM
revolt_allmotor
15
Jun 11, 2006 05:07 AM
b_serious
Nov 25, 2005 02:22 PM
Quade
Jun 13, 2003 07:16 AM
pelotudo
Feb 19, 2002 03:03 PM
