USDM pistons in a LS block
I have a B18b or B18A1 IDK remeber and some USDM ITR pistons. The pistons say P73a on them. Im trying to get the pistons NDI'ed becuaser I bought them off of ebay and dont or cant tell if they are any good.
MY QUESTION IS : are these pistons going to fit in this block because I read some were that the oil squiters are different or something? If I cant throw these in the block what would be a good combo as far as piston rods for a NA application. no nvtec
This is my first build. I want to build up a all motor beast. My inspiration BisiMoto. If you know what I mean.
They will work fine and as for rods just use the ls ones and get them shot peened, install arp rod bolts and resize them and you will be good to go. It would also be a good idea to have everything balanced as a rotating assembly.
ITR pistons on ls rods will need some machining. Either machine the piston wrist pin slots wider for the ls rods to fit, or machine the ls rods thinner to slide into the piston end.
I think I have a GSR crank in storage . I just want to make sure before I spend the money to get this stuff machined. I know how critical and precise engine building is and would hate to make a mistake after so much work
compwc18
10
Mar 2, 2004 08:15 AM
