Found coolant in my oil..HELP!!
Old Dec 7, 2008 | 07:29 PM
919DumpedCD5's Avatar
Default Found coolant in my oil..HELP!!
I have an h22 in my 95 accord. I found coolant in my oil. What problems can this cause? and how can i fix this problem? I think its a blown headgasket. Is there a diy on here on how to replace a headgasket? any advice would be great. thanks.
Old Dec 7, 2008 | 08:43 PM
P_Adams's Avatar
You may find a tutorial (and a manual) here http://www.hondahookup.com/manuals/
You look for the Prelude SI VTec version. That will cover the H22
P
Old Dec 7, 2008 | 08:58 PM
josh's_accord's Avatar
i would change head gasket and have head and block checked out to make sure nun is warpped. and if you havent already change out the timing belt, tensioner and water pump
Old Dec 7, 2008 | 09:07 PM
YeuEmMaiMai's Avatar
take it out and rebuild it, if you goot coolant in ur oil, your main bearings are TOAST.....
nghtshd88
Apr 23, 2011 03:31 PM
done
Aug 22, 2005 06:26 AM
m3dia_lab
Aug 22, 2004 04:21 PM
Sam268
Mar 2, 2004 10:20 PM
ithrowpoop
Jun 12, 2003 03:19 AM
