new to hondas need help with my hatch
Hey guys I'm kinda new to hondas and I need help. I have a 94 hatch cx with a d16z6 and when I start the car up it starts at 2500 rpms then goes up to 3200 and stays there and there is a high pitch whinning noise coming from the motor.
Adust the FITV. Does it surge once warmed up?
I dont even know what that is... ill give it a shot.. FUEL INTAKE THROTTLE VALVE???? well the high pitch noise might be from the alternator belt.. I could be wrong.. even after the motor is warmed up it stays at 3200rpms?? wow high.. it should be at 900rpms.. check your throttle cable and make sure its not to tight and its not opening the throttle body.
Fast Idle Thermo Valve (FITV), if your car surges once warmed up take off the Idle Air Control Valve (IACV) and clean it with brake and/or carb cleaner. Also by disconecting you Trottle Positioning Sensor (TPS) or Manifold Absolute Pressure Sensor (MAP) when the car is runing if thiers a change in the way it idles then it could be one of those, if no change then TPS and MAP are okay.
FITV = Fast Idle Thermo valve. x] Its on the bottom of your throttle body. If you take it off there is like a plastic retainer that holds back a metal "ball". If you tighten down the retainer then your warm up idle should drop. Try cleaning your IACV [Idle air control valve] and checking for vacuum leaks.
Yeah yo any honda engine I can think of, it acts like a choke. Pull the intake off and just inside the throttle body should be a 1/2inch hole thats the FITV (leads to the FITV). Once your car is warmed up see if air is being sucked through that hole, also when your car is cold put your finger over that hole and see if the idle slows down any.
No...pretty much anything honda/acura had in the late 80's into the early 00's.
There could be multiple issues with your car to make it do this...did you buy it like this, or did it just start doing it recently to you...do you have any more info?
Yea when I traded to get the car it was making this noise and the guy I got it from didn't have an answer for it makin the noise but ill try what u guys told me and see if it works
yamarx1
Honda Ruckus and Scooters
Aug 14, 2018 04:58 PM
