High compression on stock b16 !?
Old Dec 7, 2008 | 02:22 PM
cioli's Avatar
Default High compression on stock b16 !?
I have an b16a2 ( 160 hp ) civic.For the moment i have just a CAI and exhaust and a socketed ECU prepared for chipping.
I was thinking to rasie my compression at about 11.5 by milling the head with about 0.04 inch ( 1 mm ).My concern is that the piston could touch the valve ( also i have stock cams ) or maybe is too much compression on the stock motor and pistons would be a problem ?
Also would i need some dyno tune or just a set of cam gears ( to put the timing back to place ) and retard the dizzy manual a little bit would be enough ? And highest pump fuel of course.
Opinions ?
Old Dec 8, 2008 | 05:09 PM
cioli's Avatar
bump !?
Old Dec 8, 2008 | 07:17 PM
mario_pic's Avatar
Originally Posted by cioli
bump !?
go to a shop mill ur conrods 3 mills on each side to fit ctr pistons and ur all ready to go costs less and works better
3easy21
Apr 2, 2013 12:25 PM
94teg_RS
Sep 13, 2004 05:16 PM
KillaB-
Aug 9, 2004 08:11 AM
Slava.
Apr 13, 2004 11:13 AM
civic ex si
Feb 10, 2004 06:09 PM
