oil flooded in the spark plug area
Old Aug 2, 2002 | 09:50 AM
3rdGteg's Avatar
Default oil flooded in the spark plug area
I'm thinking that it's just the spark plug boot seals need replacement.....someone else said it could be a blown head gasket. I thought there would be oil in the coolant; or leaking between the head and the block; or overheating when the headgasket is blown. Someone, please comment on this. Need to know soon. Thanks.
Old Aug 2, 2002 | 10:13 AM
Civic1992DX's Avatar
Default Re: oil flooded in the spark plug area (3rdGteg)
I'd do a compression test. Is the top of the spark plug also oily? If so, check that little gasket (rubber washer).
Yuri K
[Modified by Civic1992DX, 7:14 PM 8/2/2002]
Old Aug 2, 2002 | 10:25 AM
slickboy's Avatar
New User
Default Re: oil flooded in the spark plug area (Civic1992DX)
Make sure your valve cover bolts are torqued properly. That happened to my sisters' 92 Accord...the bolts were so llose I took them off by hand. I retorqued them and they've ben fine ever since.
Old Aug 2, 2002 | 10:38 AM
3rdGteg's Avatar
Default Re: oil flooded in the spark plug area (slickboy)
Yeah I'm gonna check the seals and torque, but I'm trying to figure out the worst case scenario if it could be symptoms of a blown head gasket which I greatly doubt. The car never overheated at all, just some funny oil burning smell.
Oh yeah Yuri, that is where the oil is at......when I pull the spark plug wires out, there's oil all in the sockets.
[Modified by 3rdGteg, 7:40 PM 8/2/2002]
Old Aug 2, 2002 | 10:56 AM
Gennady's Avatar
New User
Valve cover gasket.
Old Aug 8, 2002 | 10:15 PM
3rdGteg's Avatar
Default Re: oil flooded in the spark plug area (Wont be beat)
It was the three center "valve cover bolts" not tightening up. I can't even take the bolt off to open the valve cover; the bolt just keeps spinning and spinning either way I turn it. Noticing that, I pulled the spark plug wire out and stuck my finger down in-between where the valve cover sits on a spark plug boot seal mating against the internal parts of the head and noticed a little gap where oil could have gotten through and into my spark plugs. Now I'm just stuck on how to pull them valve cover bolts off and fix either the studs or bolts.
Old Aug 8, 2002 | 10:43 PM
rocket_R's Avatar
i was told awhile back that it could also be cause by a bad piston ring might want to check that to..
Old Aug 9, 2002 | 06:03 AM
Dutchie's Avatar
Go to Honda and get a new valve cover gasket, the four round gaskets (that's what is causing the oil leakage), and a couple new studs. Get a pair of visegrips and break that nut off. Then just replace that stud, you can get it out with the visegrips.
Old Aug 9, 2002 | 12:04 PM
3rdGteg's Avatar
Default Re: oil flooded in the spark plug area (Dutchie)
yeah, it's those 4 round spark plug boot seal that needs to be replaced; but what if it's those studs are the one spinning in the head and not just the valve cover bolts, how hard would it be to retap a new stud in there (if they even have any bigger stud to replace the stock ones).
ducsaim
Apr 15, 2020 09:10 PM
sl0whatch
Jun 1, 2010 06:15 PM
teddy_dc2
Jan 4, 2007 07:11 PM
Eg6xCiViCxSi
Dec 17, 2005 03:38 PM
luciffer
Mar 18, 2005 07:43 AM
