At what point does a turbo kit become NOT smog legal?
Old Aug 2, 2002 | 08:32 AM
YodaIsGod
Guest
Posts: n/a
Default At what point does a turbo kit become NOT smog legal?
I know the GReddy kit is smog legal. But if you add.....what? Then it's not?
What parts and why?
New to the turbo stuff.
GSRgrrl's turboed GS-R got me thinking......
Old Aug 2, 2002 | 08:39 AM
The_Head's Avatar
Default Re: At what point does a turbo kit become NOT smog legal? (YodaIsGod)
I'm going to throw out a guess and say its the 12:1 FMU. Probably makes it run too rich too pass emissions when its boosting.
Old Aug 2, 2002 | 08:40 AM
paulzy's Avatar
Default Re: At what point does a turbo kit become NOT smog legal? (xThexHeadx)
the external wastegate and the BOV venting to atmosphere
[Modified by Slow_ass_4dr, 9:40 AM 8/2/2002]
Old Aug 2, 2002 | 09:06 AM
dbman96's Avatar
New User
Default Re: At what point does a turbo kit become NOT smog legal? (Slow_ass_4dr)
External wastegate venting to atmosphere is key... also the fact that a large turbocharger cools down the exhaust enough that it makes the catalytic converter significantly less efficient, especially on startup. Even with perfect fuel tuning it won't burn as clean as a non-turbo car, unless you take some serious measures with startup fuel and ignition to heat up the catalyst.
Old Aug 2, 2002 | 09:35 AM
YodaIsGod
Guest
Posts: n/a
Default Re: At what point does a turbo kit become NOT smog legal? (dbman96)
how does Subura pass emmisions?
Old Aug 2, 2002 | 09:37 AM
LsTurbo91's Avatar
you will fail "the visual inspection"
Old Aug 2, 2002 | 12:15 PM
Smashback's Avatar
If you add things, most of the time those boners won't notice because they really don't know much about cars anyway.
Either they'll pass you with the carb sticker, or they'll fail or not inspect you because they don't know what is what. A place here wouldn't inspect me for having a cone air filter before I had the turbo on.
As far as I know, air filters do not have to be carb approved. Depends all on where you go though.
Old Aug 2, 2002 | 12:49 PM
Etylorcen's Avatar
Default Re: At what point does a turbo kit become NOT smog legal? (mplex2000)
The extra fuel pump and fmu will make you fail visual like that.
Old Aug 2, 2002 | 01:28 PM
RuthlessEF-9's Avatar
Default Re: At what point does a turbo kit become NOT smog legal? (Etylorcen)
subaru doesn't have an external wastegate
Old Aug 2, 2002 | 02:49 PM
HXMan's Avatar
Default Re: At what point does a turbo kit become NOT smog legal? (ruthlessSpecR)
Here in wisconsin it is Illegeal to have an open air filter element. Making pretty much all aftermarket filter systems Illigeal.
Old Aug 5, 2002 | 10:14 PM
dbman96's Avatar
New User
Subaru has THREE catalytic converters, one of which goes BEFORE the turbo, for the sole purpose of reaching operating temp soon enough to pass US emissions on startup.
Old Aug 5, 2002 | 10:30 PM
rjardy's Avatar
Subaru allso vents it's bov back into the intake. steering away from atmospheric venting.
Rob
ReggieGrip
Mar 6, 2010 07:33 AM
ThaCivicAssassin
Mar 22, 2005 03:21 PM
SPOONup
Jan 7, 2005 01:25 PM
SPOONup
Jan 7, 2005 12:18 AM
wonny
Dec 10, 2002 03:07 PM
