spark plug drenched in oil!!!
Old Dec 5, 2008 | 03:30 PM
.:urbandc2:.'s Avatar
Default spark plug drenched in oil!!!
So... I'm currently working on a single cam zc.. When I checked the plugs, one came out drenched in oil.. The spark plugs are black.. Checked the compression, it's hella low.. I can smell as if it was running rich.. It backfires once u try and turn it on..
I'm changing out the gaskets and plugs..
Would anyone happen too know what causes this or how can it be fixed?
Old Dec 5, 2008 | 03:42 PM
EFstyle's Avatar
Chances are it's your rings... if it where valve seals then compression wouldnt drop that low. just my thoughts but i could be wrong
Old Dec 5, 2008 | 03:45 PM
91crx-jace's Avatar
Rings fa sho. sounds like its time 4 a dual. lol
Old Dec 5, 2008 | 03:51 PM
Deetz's Avatar
Crazy Honda Guy
Was it the top of the plugs covered in oil? If so, change out your tube seals....they are cheap and easy to change.
Old Dec 5, 2008 | 03:54 PM
91crx-jace's Avatar
true...didnt think about if it wuz the top or bottom of the plugs...lol
Old Dec 5, 2008 | 03:57 PM
EFstyle's Avatar
either way hes getting "low" compression, a number would be nice to work with
Old Dec 5, 2008 | 04:08 PM
Default .
The spark side of the plug was drenched in oil..
Now, what would cause the rich smell?..
Old Dec 5, 2008 | 04:10 PM
91crx-jace's Avatar
timing.... and im 90% sure its the rings...
Old Dec 5, 2008 | 04:11 PM
EFstyle's Avatar
what where your compression test results?
Old Dec 5, 2008 | 04:12 PM
91dxsedan's Avatar
unspent fuel due to low comp. prob have blowby
Old Dec 5, 2008 | 09:14 PM
Default .
my mistake.. I just completed a compression test on all cylinders and they all came out at 150.. I took out the plugs and looked inside, seems as if all pistons have a thick coat of oil.. The plugs and gaskets were changed.. Even then, when I try starting the car, it boggs out.. I checked the firing order and it's correct..
WTF!!!!.. Lol
Old Dec 6, 2008 | 04:04 PM
Default .
anyone?
Old Dec 8, 2008 | 09:00 AM
ef89's Avatar
i had the same problem in my 88 hatch all my plugs were coming out oil soaked and i had a spuddering problem and one of my cylinders wasnt firing. after changing the rings and some new items on the firing side of things she was running ship shape.
Old Dec 8, 2008 | 09:58 AM
dan-lee's Avatar
rings ...
Old Dec 8, 2008 | 10:00 AM
Jas9848's Avatar
Rings and possibly valve seals, but rings for the compression also.
Old Dec 8, 2008 | 12:28 PM
Nang's Avatar
yeah try to change the O ring
sedlmeier101
Sep 4, 2007 09:15 AM
KloC 95 EG
Sep 4, 2006 09:14 PM
respectblades
Mar 5, 2003 01:24 PM
PressurizedSi
Nov 29, 2002 03:48 AM
Digital-R
Aug 3, 2001 11:07 AM
