Skunk2 pro 1s vs. itr cams
Old Dec 5, 2008 | 12:53 PM
turboD_EG's Avatar
Default Skunk2 pro 1s vs. itr cams
Im looking to make hp in the upper 500 to lower 600 range. I have a new set of itr cams and wanted to know if it would be worth buying the pro 1s or not? here is my setup.
p&p gsr head with ferrea valves,valve springs and ti retainers, skunk2 cam gears
eagle rods
je 9:1 pistons
holset hx40 turbo with ramhorn manifold and tial 44mm wastegate
let me know what you guys think? if you think i sould change anything on my stup pleasr let me know! thanks
Old Dec 5, 2008 | 01:40 PM
92civicx's Avatar
pro 1s are more aggresive than type rs
Old Dec 5, 2008 | 01:51 PM
B18c1turboedEK's Avatar
Nope!!
Old Dec 5, 2008 | 02:12 PM
Blown90hatcH's Avatar
NO. Keep the ITRs.....especially if it is a street car.
Old Dec 5, 2008 | 02:16 PM
silkyjohnson#1hater's Avatar
why?^^
Old Dec 5, 2008 | 02:54 PM
fmfkid250's Avatar
Tony1 did a test a while back Search it up!
Old Dec 5, 2008 | 03:17 PM
just read the test and they work and make more power than stock itr, why are people saying dont get them?
Old Dec 5, 2008 | 03:24 PM
tony1's Avatar
because ITR's are better for a street car. The Pro 1 is a very aggressive cam and the idle and driveability will suffer compared to ITR's. His goals are simple, ITR's will easily do that.
Old Dec 5, 2008 | 03:28 PM
ok and thats stage 1 cams? i ask cuz i just put those in my motor
Old Dec 5, 2008 | 03:58 PM
ABK's Avatar
ABK
pro 1s are far from s2s1. ITR cams are pretty much s2s1.
Old Dec 5, 2008 | 04:35 PM
got wide's Avatar
im running the pro 1's in my setup. i dont really have any drivability issues but i cant really idle under 850-900 reliably, which i really dont mind because they DO make more power. i think sean at s2 told me they made 80hp more than the itr cams on there integra.
Old Dec 5, 2008 | 05:19 PM
b20beast83's Avatar
while we are on the topic i hope i could ask a question
i have R Cams in my motor, should i sell them to make money for my boost project and just put in the b16 cams?
or are the itrs worth it?
Old Dec 5, 2008 | 05:26 PM
swapit's Avatar
I switched from a type r to s2 tuner 2s and had good results and my car drives and idles like stock w/1600s and no injector driver.i made 61whp more when switch from type r cams and e85 to the tuner 2s on q16 on less boost.
but for his horepower goals type r cams are sufficent
Old Dec 5, 2008 | 06:42 PM
HAMOTORSPORTS's Avatar
definetely run the Pro 1's. Just lean out at IDLE and throw a few degrees timing in at IDLE only and it will be great on the street and spool much sooner. Pro 1's are far from being too much on the street. We've run many Pro2 all motor setups in daily drivers with great results. Just make sure theyre degreed right and pull some fuel away at idle and you'll be doin great!
Old Dec 5, 2008 | 07:39 PM
locash's Avatar
I'd suggest the ITR cams, as stated, your goals aren't that difficult to achieve with them, and the big plus here, you get OEM reliability. This is very important in a street car. Plus, think of all the money you'll save, you can spend that on gas and beer.
Miracle11
Jun 2, 2010 09:07 PM
VTEC2841
Apr 29, 2007 08:16 PM
Andrew Sutherland
Dec 10, 2006 12:33 PM
teggy182
Mar 26, 2006 09:01 PM
