Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Old Apr 6, 2015, 09:26 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
2003 Accord V6 Coupe - Performance Mods (headers?)
Old Dec 5, 2008 | 12:39 PM
zsracing's Avatar
Default 2003 Accord V6 Coupe - Performance Mods (headers?)
Hello everyone, just joined the forums last night. I recently purchased a 2003 accord v6 auto coupe. I have searched all over for v6 headers and I am convinced they do not exist. If they do, could you direct me in the right direction. If not, I would be willing to let someone in the DFW area borrow my car to make custom ones for production. Anyways, what other performance mods exist. What's a decent dual exhaust setup, camshafts, intake, etc...
I heard underdrive pulleys are not good in climates with high temperatures such as texas. Let me know what you think.
Old Dec 5, 2008 | 01:36 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
The reason you can't find headers for your Accord v6 is that they can not exist. The initial portion of the exhaust manifold is physically welded to the cylinder head, and can't be removed. You can, however, replace all three of the catalytic converters, and the downpipe(whatever you choose to call it, the pipe between the manifold and midpipe). The first two catalytic converters, right off the exhaust manifolds, are the ones that actually utilize an O2 sensor, so replacing them might not be smart on a daily driven car. The third one, at the normal spot under the middle of the car, has no sensors and is pretty much only there to let Honda stamp "ULEV" on the car. I replaced that in my Accord along with the downpipe/J-pipe and I absolutely love the increase in torque at all RPMs, and it only cost me $350 for both.
For the exhaust, I would recommend the Magnaflow catback, as you can find them for $500 shipped, and they sound wonderful. The Greddy exhausts looks too ricey to me, and also costs about $900, but I've heard it produces the best power. The Borla also sounds decent, and is about the same price as the Magnaflow, maybe a little more. For the intake, the AEM v2 is the common choice, and I believe there in an Injen intake that is a little cheaper. You can get a UR underdrive pulley or pulley set, but as far as aftermarket cams and other engine upgrades, there isn't really anything yet, unless you want to make some sort of hybrid J series engine using larger displacement blocks from the 3.5 engines, and/or the cams and valvetrain from the current TL Type S.
Old Dec 7, 2008 | 09:19 AM
zsracing's Avatar
Do you have a link to to these parts that you replaced, or could you point me in the right direction?
Old Dec 8, 2008 | 01:05 PM
This is the downpipe/test pipe I purchased, and I thought it was the best bolt-on mod I've ever done to any car. $360 for both shipped. http://www.v6performance.net/forums/...ad.php?t=99609
I can't remember where I found the Magnaflow for dirt cheap, but I searched for it on Yahoo and it was some kind of 4x4 website, to give you somewhat of a direction to look for it.
Old Jul 3, 2011 | 10:05 PM
brazilan's Avatar
Default Re: 2003 Accord V6 Coupe - Performance Mods (headers?)
yes they do have them for v6 o3
Old Jul 5, 2011 | 07:55 AM
johnnykash's Avatar
best bang for your buck mods. jpipe/precat deletes and a custom exhaust.
Old Jul 5, 2011 | 10:24 AM
helgi54's Avatar
Would love to see and hear that after its accomplished!
Old Jul 6, 2011 | 07:14 PM
johnnykash's Avatar
good sound for sure!
Old Oct 23, 2013 | 07:29 PM
andrewhbb22's Avatar
where did you got the headers from ?
Old Oct 28, 2013 | 06:48 PM
CM6's Avatar
CM6
As was mentioned above, the V6's do not have "headers." The first part of the exhaust before the pre-cats is welded onto the cylinder head.
The modifications discussed above are the high flow J-pipe, catalytic converter deletes, and cat-back exhaust. A google search will more than suffice for finding these parts online.
Old Oct 28, 2013 | 07:05 PM
BLKFLSH's Avatar
The header is eliminated, because the head is made with it built in. There is only one exhaust hole in the head itself, where the downpipe/cat converter is bolted. Click on the link below, and look at #2 in the illustration.
http://www.1hondaparts.com/parts-cat...ission-assy-v6
cskinner89
Apr 7, 2010 05:15 PM
GR_DC2
Jan 11, 2008 09:31 AM
newcardirector
Sep 17, 2004 10:54 AM
Variance
Mar 12, 2004 04:05 PM
03whiteaccord
May 14, 2003 08:15 AM
