92 civic i think the torque converter isnt locking
Old Dec 5, 2008 | 11:55 AM
krisfnbs's Avatar
Default 92 civic i think the torque converter isnt locking
Car shifts fine, until its on the highway and it wont "click" or "lock" into the cruise gear. Usually around 70mph the RPM is around 2.8-3ish and now its around 3.5 and you can hear the engine louder obviously.
What could it be?....
Old Dec 8, 2008 | 07:26 AM
krisfnbs's Avatar
ttt?
Old Dec 8, 2008 | 07:33 AM
freakasis's Avatar
did you check the trans fluid? also the trans could be going out, how many miles on it? was the fluid changed regularly?
Old Dec 8, 2008 | 07:36 AM
94EG8's Avatar
Seagull Management
Any CELs?
Old Dec 8, 2008 | 07:39 AM
Vindicator9000's Avatar
318 Curves, 11 miles
definitely check trans fluid level first. Too high or too low can cause slow or non-shifting conditions in my experience.
Old Dec 8, 2008 | 08:44 AM
1LowSol's Avatar
+1
Old Dec 8, 2008 | 08:46 AM
krisfnbs's Avatar
I changed the trannt fluid like 3k miles ago. completely stock 92 civic w/ 210k. never had any tranny problems. shifts fine
Old Dec 8, 2008 | 09:00 AM
krisfnbs's Avatar
Originally Posted by 94EG8
Any CELs?
no cels
Old Dec 8, 2008 | 09:02 AM
krisfnbs's Avatar
well you make a good point.
I changed the tranny fluid back around 3k miles ago, and I only put in 2 quarts. the car sat for about a month or two before I started driving it again, and I had read somewhere that my tranny holds almost 3 quarts so I went ahead and I added another quart... or about .8 or a quart or so.
Now I dont know if it was locking into "overdrive" or whatever you want to call it on the highway when it had 2 quarts, but it def doesnt at 3 quarts.
Wtf???
Old Dec 8, 2008 | 09:07 AM
freakasis's Avatar
what does the dipstick say now? low? high? what?
Old Dec 8, 2008 | 09:24 AM
krisfnbs's Avatar
im at work, so I cant check it now.
I know where to look for the oil marks when checking the oil, on the tranny I knew there are 3 X's... where should it be if its the correct amount? I also would assume turning the car on while checking would be the right way to do it.
eddieE
Honda Civic (2006 - 2015)
Feb 4, 2013 05:12 PM
QueizaG
Aug 26, 2009 10:46 AM
wishingiam
Transmission & Drivetrain
Jun 25, 2009 01:14 AM
Arkiados
Mar 16, 2007 10:47 AM
D16Z6_turbo
12
Jul 31, 2005 05:27 PM
