civic keep blowing thremostat
Old Dec 5, 2008 | 10:47 AM
young geezer's Avatar
Default civic keep blowing thremostat
well my girl crashed into someone like a month ago and messed up the front end. after a month ago there is smoke comeout from the radiator or around it. then the heater blows cold air. so i replace the thremostat and it worked fine for little bit. then again yesterday there was smoke coming around the radiator and now blows cold air again. can anyone tell me what could be the problem? thanks.
Old Dec 5, 2008 | 11:04 AM
Marauder's Avatar
Its not the thermostat....i'd say you are losing coolant.
Any water under the car? the heater blowing cold means that you have air in the system, so the water is getting out somwhere.
Old Dec 5, 2008 | 11:09 AM
MadScientistMatt's Avatar
Definitely a coolant leak. If that's a stock type radiator, the first thing I'd look for is signs the plastic end tanks are leaking where they meet the metal center section. That happened to me before.
Old Dec 5, 2008 | 11:12 AM
teamworxek9's Avatar
its your radiator, she most likely cracked it.
Old Dec 5, 2008 | 11:16 AM
TomO's Avatar
If there is steam (smoke, water vapor) coming from the radiator; you either have a cracked endtank (common, especially after an accident involving the front end), a loose hose connection, or corroded tubes that are leaking.
Replacing the radiator/finding the leak is the first step.
sir4doorking
16
Jul 8, 2015 09:27 PM
chikin pickle
Sep 17, 2009 02:59 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
dhn
23
Jan 5, 2008 01:06 AM
I3ooS710
Mar 25, 2006 03:45 AM
