jdm d15b question
D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
1992-1998 Honda CRX VXi EG1 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Compression : 9.6:1
Power : 128.22 hp (130 ps) @ 6800 rpm & 101.9 ft·lbs (14.1kg/m) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Head Code : P08
Fuel Control : OBD-1 MPFI
D15B (D15Z7) (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Power : 128 hp (130 ps) @ 7000 rpm & 102 lb·ft (14.2kg/m) @ 5300 rpm
Fuel Control : OBD-2 MPFI
http://en.wikipedia.org/wiki/Honda_d_engine#D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
TravisCadello
18
Nov 29, 2015 06:52 PM
