dizzy problems need help!!
Old Dec 4, 2008 | 07:50 PM
dcsports's Avatar
Default dizzy problems need help!!
my car has a problem i gone though 2 coils now my car was turning off with the first one my rpm guage was going nuts missfiring first i changed the ignitor had no change wat so ever then the car started turning off and i knew it had to be the coil so i changed it worked good no more missfiring ran smooth but only problem my rpm guage was still acting up and now today now i feel the missfiring again and this coil is about to take a dump also i just want to know what could be causing this? i changed cap and rotor
Old Dec 4, 2008 | 08:05 PM
saywhat's Avatar
Check your timing, and make sure your wires are going to the correct cylinders.
Old Dec 4, 2008 | 08:07 PM
dcsports's Avatar
checked timming i have to check the wires no check engine light also
Old Dec 5, 2008 | 04:44 PM
saywhat's Avatar
Maybe a loose ground somewhere?
Old Dec 5, 2008 | 05:03 PM
honda_boy23's Avatar
i would say timing, a short somewhere, maybe a check yr plugs to see if any are fouled
Old Dec 7, 2008 | 06:30 PM
dcsports's Avatar
i will check my grounds but i changed the plugs after it already had started
Old Dec 7, 2008 | 06:54 PM
raidacaipo's Avatar
if I were you check timing, then replace spark plug wires as well as spark plugs.. see if that helps.. also cap and rotor but you replaced that already.
emooheo
Aug 18, 2007 11:27 AM
13link EG
Jul 1, 2006 04:18 PM
psegs80
Jul 29, 2005 02:32 PM
GreenEggs248
Aug 5, 2004 11:22 PM
CustomTeggy44
Apr 29, 2004 10:38 PM
