JDM B20 into 00 EK (EM1)
Old Dec 4, 2008 | 04:05 PM
david76008's Avatar
Default JDM B20 into 00 EK (EM1)
I'm putting a JDM B20 in my car, and have encounter a few problems.
1) What Wiring harness should I use?
2) What ECU should I use.
I was thinking of the stock CRV wiring harness, and an OBD1 LS computer to get rid of a few CEL. And of course, an OBD2b to OBD1 jumper.
The car is going to be a stock B20, and daily driven.
Thanks so much!
Old Dec 4, 2008 | 04:13 PM
LA_HONDAS's Avatar
use your stock engine harness
a chipped obd1 ls ecu with a b20 base map will do (link phearable.net)
Old Dec 4, 2008 | 04:16 PM
david76008's Avatar
Problem: Sold it already lol. And it had the Vtec plug anyways.
Old Dec 4, 2008 | 05:20 PM
LA_HONDAS's Avatar
well you gotta fine a 99-00 civic engine harness
on a side note you cant use a integra engine harness and a 96-98 civic harness
Old Dec 4, 2008 | 05:22 PM
david76008's Avatar
Why not?
Old Dec 4, 2008 | 05:31 PM
LA_HONDAS's Avatar
cuz there not same
the 94-01 integra harness is like the 92-95 civic harness
and 96-98 civic harness have all 3 ecu plugs on it
the 99-00 civic harness have 2 ecu plug on it and the other one is the dash harness
Old Dec 5, 2008 | 04:17 AM
david76008's Avatar
Anyone else have any comments?
Old Dec 5, 2008 | 04:26 AM
bronx finest's Avatar
get back your 99-00 Si harness fool. there is no other option.
Old Dec 5, 2008 | 04:43 AM
david76008's Avatar
can you explain to me why. It's not a vtec motor, so its fine if that plug just sits there? and will any other harness work?
Old Dec 5, 2008 | 05:16 AM
chad's Avatar
Moderator
the answer has been given to you already....
USE A 99-00 SI HARNESS if you don't want to run into problems...
yes those plugs can just hang there!
Old Dec 5, 2008 | 05:42 AM
That's fine if the 'vtec plugs' just sit there, also any other 99-00 Civic engine harness would work, but its good to have EX/Si harness in case you ever go vtec again.
Other harnesses have different emissions/sensor equipment. Its always best to use your chassis specific harness, and just use a stepdown for ECU purposes. Reason being, a lot of things are different in 6th gen Civics ('EK') than the EG or DC chassis.
Old Dec 5, 2008 | 09:07 AM
david76008's Avatar
Thats what I was looking for.
Thanks so much.
And Im on the right track on the ECU right?
Old Dec 5, 2008 | 09:51 AM
LA_HONDAS's Avatar
yes your on track with the ecu
Old Dec 5, 2008 | 09:54 AM
Thanks so much.
No prob, anytime.
Yes you are on track with the ECU as well.
david76008
Feb 5, 2009 06:18 AM
irideslammed5021
May 14, 2007 11:00 AM
BoltonGSR
Apr 26, 2007 07:14 AM
DevinW
Apr 7, 2003 10:29 AM
DevinW
Apr 7, 2003 04:08 AM
