what head bolts to use for ls/vtec????
the b16 ones should be fine if you are not making mega power, but people have recommended using the gsr because they are a little longer
DO NOT use B16A headstuds. They are about a 1/4" too short. Use either GSR or ARP GSR headstuds. Running the b16 headbolts will increase teh likelyhood of blowing a headgasket.
[Modified by WAFFLES, 2:02 PM 8/2/2002]
can i just jump in and say:
if you want to, use ARP GSR head studs (PN 208-4303) and ARP 8mm LS rod bolts (PN 208-6001).
these fit teh B20VTEC and LS/VTEC engine.
t..
[Modified by tinkerbell, 6:07 PM 8/3/2002]
t..
if you're gonna do it you may as well do it right
go with arp, i have ls/vtec and have had no blown headgaskets and everything is runnin good
