is this possible?
Old Dec 4, 2008 | 03:20 PM
brandon2000's Avatar
Default is this possible?
i have a 91 civic hatch, and i was wondering if it is possible to swap the stock d15 with a b16 without changing the tranny or anything like that?
if not can you suggest the most price friendly way to get more power out of the d15.
im new to hondas so please dont be rude.
Old Dec 4, 2008 | 03:23 PM
ef9_b20's Avatar
i aint gonna be rude like most dudes here, but no d series parts and b series dont interchange like that....i dont know anything about d series lol ive only fooled with b series :/
Old Dec 4, 2008 | 03:30 PM
well thanks for being courteous. would it be better to do a full swap and invest 1500 for a whole new front clip, or just get a new d15 and upgrade it?
Old Dec 4, 2008 | 03:37 PM
bprsk8r4272's Avatar
why did you want to use the stock tranny(although you cant) ? why not juss do the b16 swap?
Old Dec 4, 2008 | 03:39 PM
ef9_b20's Avatar
yea if your looking for power swap to a b, go with gsr over b16 though..
Old Dec 4, 2008 | 03:51 PM
i was just asking because i was trying to find the most cost efficient way to get more power out of my current set up.
i mean i would rather just upgrade my d15 rather than spend 1500 on a b16. but i was asking because i dont know what is better to do
Old Dec 4, 2008 | 03:52 PM
what kind of ups to a d series would i need to match the performance of a b series?
Old Dec 4, 2008 | 04:03 PM
gator88's Avatar
bisi level 2 ground to your needs $229, .040 milled off the head $25 for me, thinner head gasket $80, 92 octance. $150 to $250 for a nice Si tranny. walk a b16 all day long. Wont blow em out of the water, that is for sure, but a lot more fun than stock and pretty damn cheap and easy.
Old Dec 4, 2008 | 04:11 PM
Originally Posted by gator88
bisi level 2 ground to your needs $229, .040 milled off the head $25 for me, thinner head gasket $80, 92 octance. $150 to $250 for a nice Si tranny. Pull a b16 all day long.
what is a level two ground?
Old Dec 4, 2008 | 04:13 PM
gator88's Avatar
it is a cam regrind. Dont get me wrong, you wont smoke a b16 with this setup, but it is a very nice increase over stock and is what I am putting together right now with my a6. I have driven an identical car to mine with this setup and it was a blast, only difference it had slightly higher comp pistons that stock.
Old Dec 4, 2008 | 04:14 PM
justa4banger's Avatar
swap your d15 for a d16z6 and boost the mother "ef" er
Old Dec 4, 2008 | 04:17 PM
oh ok. im also planning on doing bolt ons too, so im pretty sure im just going to keep the d series, its just kinda hard to find quality parts cuz passwordjdm.com and such usualy only carry b series parts =/ any suggestions?
Old Dec 4, 2008 | 04:18 PM
LittleRedDX's Avatar
i went from a d15 to a d16y7. I took the stock 1.5 sohc out of a 93 dx and put a 1.6 sohc vtec that I got from a 96 ex. I had to do the entire wire harness from the headlights to the taillights. I sucked but it was totaly worth it.
Old Dec 4, 2008 | 04:24 PM
ya i was thinking about a d16, but how noticable is the power increase?
is that the same as a zc?
Old Dec 4, 2008 | 04:31 PM
Red_ED8's Avatar
If you just want some extra pep out of your d15, swap to mpfi, get a D16A6 cam, and pm6 ecu. And if you do swap, please don't waste your money on a B16. There torque less and not much faster the a D16.
Old Dec 4, 2008 | 04:37 PM
ok. if i do a swap i am considering putting in a d16 zc
but im not sure if it is compatible with the stock tranny and such
Old Dec 4, 2008 | 05:03 PM
~sp33~'s Avatar
EFB055
Your D series engine will be compatible with your D series transmission.
Old Dec 4, 2008 | 05:06 PM
Rockgate's Avatar
I did a mini-me last year. I can tell a good difference and it didn't cost that much. Just shop around. Gained 6/10ths in the 1/8 mile. But definitely has problems getting traction.
Old Dec 4, 2008 | 05:43 PM
gator88's Avatar
Here is where 2 places I am going to be doing my shopping
www.bisimoto.com level 2 cam and his cam gear
www.exospeed.com valve springs
many, many more. Depends what you are looking for. I like ebay because I am on a budget and it is good for used headers etc. Little things that saving a buck or two will add up to more parts i can buy.
Old Dec 4, 2008 | 08:31 PM
acmoc's Avatar
supercharger, lots of fun, i plan for one next year
Old Dec 4, 2008 | 08:45 PM
rsnupt82's Avatar
either u buy a turbo for your d15 or you buy a stock b16.... either way u end up wasting about 1200 minimum. a turbo d15 would be faster i beleve,,,
fredo818
May 14, 2011 10:03 PM
00EckoSI
23
Nov 7, 2009 05:22 PM
93DelSolS
Aug 23, 2009 01:37 PM
meatdentist
Nov 14, 2005 11:06 PM
