Can Someone tell me what is this sensor called? on a 1994 Accord
Well, this sensor is broken and full of oil and has my car acting up when i try to turn it on...i just got another one from the junkyard to replace it...Im just wondering what is it called...as soon as i remove it or touch it, I get the check engine light on and the D4 Flashing with out stopping. 1994 acord LX auto...4cl
CHECK OUT THE LINKS...THANKS!
http://img229.imageshack.us/my.php?i...img4092er6.jpg
http://img155.imageshack.us/my.php?i...img4090jg2.jpg
From your pictures, it is still very hard to see the location. But, since I see the distributor, is it the sensor on top of the transmission? If so, it is the Vehicle Speed Sensor (VSS), which would cause the D4 to flash.
Check this link out to see if that is what you are referring to:
http://techauto.awardspace.com/vss.html
The 2 pin connector in the head under the distributor is a temp sensor ;
The single pin connector is for the temp gauge sending unit;
If you make the pictures a little smaller and darker I'm sure you'll get some more wild guesses.
The single pin connector is for the temp gauge sending unit.
Willy1971
Mar 25, 2019 06:32 AM
Babong
17
Sep 20, 2011 08:35 AM
r.etheridge
Feb 13, 2011 02:59 AM
