Cant Check Codes
Old Dec 4, 2008 | 01:07 PM
M7EG6's Avatar
Default Cant Check Codes
So my check engine light is on but when jump the wires to check the code it dosent flash it just stays on any help Thanks
Old Dec 4, 2008 | 01:18 PM
wrenchez81's Avatar
either your not jumping the right connector or the ecu is dunzoed!!!
Old Dec 4, 2008 | 02:13 PM
M7EG6's Avatar
i know im jumping the right one because ive done it on my oher cars and i changed the ecu to a different and still nothing
Old Dec 4, 2008 | 02:21 PM
egvtec's Avatar
try a different paperclip or wire, i somehow had a paper clip that was metal but didnt conduct the current. when i switched to another one it worked. just a thought...
Old Dec 4, 2008 | 02:29 PM
M7EG6's Avatar
i used a paper clip then a wire and nothing
Old Dec 4, 2008 | 02:49 PM
egvtec's Avatar
There is a white and blue wire coming out of the ecu to the gauge cluster, that is to send the code to the cluster from the ecu, make sure it is not cut anywhere at the ecu side or at the cluster, make sure the pin is in ok. A13 on the ecu side i think???
Its blue with a white stripe
Old Dec 4, 2008 | 02:52 PM
M7EG6's Avatar
ill check it tomorrow cause the car is currently at my work
Old Dec 4, 2008 | 02:53 PM
egvtec's Avatar
Also search the forums if you havent already, someone might have other things you can check in an old thread. Make a list then by tomorrow when u go to work of things to check.
Old Dec 4, 2008 | 03:00 PM
scuzz's Avatar
Somebody on some honda board told me to try this, and I can't remeber where, BUT, it worked.
Check the code with engine running. Short wire and start engine and light counts off. Believe it or not, it worked, and now after that, my codes show normally withour starting engine.
I was sceptical, but it worked.
Old Dec 4, 2008 | 03:17 PM
dapek's Avatar
mine is doing the same thing and i tried this and...it didn't work, just stayed lit up. Maybe because i'm OBD2, what is your car OP?
Old Dec 5, 2008 | 06:07 PM
M7EG6's Avatar
checked the wire A13 and its hooked up not cut anywhere could it be the ecu
JDMlyfestyle
588
Nov 3, 2022 12:37 PM
JDMlyfestyle
18
Apr 29, 2021 01:09 AM
christian7750
15
May 10, 2007 03:44 PM
93EH6
Jan 30, 2003 09:11 PM
