Gauges?
Old Dec 4, 2008 | 11:41 AM
columbushatch's Avatar
Default Gauges?
I am installing the aem tru boost controller and a oil pressure gauge and was wondering: Intructions stated to use a switched fused +12v source, I am assuming they are referring to ACC. is this correct?
secondly, I try to avoid cutting any factory wires so I was planning to run all the gauge and controller wires to my aftermarket cd player harness, would that be a good location?
any help would be great.
-J
Old Dec 4, 2008 | 01:31 PM
wrenchez81's Avatar
your correct on you assumption of the power source however ganging them on that one circuit is foolish!! if you have a cig lighter use that circuit and throw the element away....
Old Dec 4, 2008 | 03:58 PM
trustdestruction's Avatar
Ditto on using the cig lighter for 12V switched. It's the easiest to use and is exactly what you need.
Old Dec 5, 2008 | 06:22 AM
so just run one gauge off the radio harness and the controller off the cig outlet. thanks
-J
hangac1093
Mar 10, 2007 08:45 PM
Benjithx
Sep 8, 2004 08:59 PM
CalvitoSol
Jul 8, 2002 03:55 AM
shadowdawn
Apr 2, 2002 12:49 PM
degradated
Oct 23, 2001 02:25 PM
