Death of my D16Z6............
Old Aug 2, 2002 | 03:33 AM
Mista Bone's Avatar
D Tranny Guru
Default Death of my D16Z6............
finally got around to tear it down.....
seems part of #3 piston disappeared.
Old Aug 2, 2002 | 05:09 AM
RGAZ's Avatar
New User
Default Re: Death of my D16Z6............ (Mista Bone)
Did you blow off the entire upper ring land from ring to piston top?
Or am I seeing things here?
Randy
Old Aug 2, 2002 | 05:28 AM
CovertFI's Avatar
Default Re: Death of my D16Z6............ (RGAZ)
sweet
what did the sohc in?
Old Aug 2, 2002 | 07:08 AM
Pengo's Avatar
Default Re: Death of my D16Z6............ (CovertFI)
how long did this d-series run before it went? so what you got planned next bone? i'm sure you have something good in mind. good luck with ur next creation
Old Aug 3, 2002 | 02:40 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Death of my D16Z6............ (Pengo)
lack of nitrous (empty bottle) did in the the motor.
I bought the motor with 55k on it from a well cared 95 EX Coupe. I installed it with a LW pulley and 10,000 miles later I had the bearing incident. I installed new Honda bearings (all GREEN!) and cleened up the crank with 600 grit emery cloth. Figuring the crank is trashed I found a used ZEX kit for $350 locally. Twenty five bottles or 250 lbs of nitrous later, I finally HURT it bad. I did melt a plug a year ago on #2 piston, 15% blowby.
Now, I only paid $500 for the motor AND tranny + axles. I had a BLAST and will do it all over again!
Swap/slicks/juice I had less than $1200 invested, name a DOHC B swap that can claim that?
Next plans are a D15B VTEC using a D15B7 block, VX rods, GX Y8 pistons, for a 12.5:1 compressoin 1.5L stomper. Expect low 14's all motor using factory parts.
Now, just think what I could do IF I had the money to play with a B swap?????
Alot of people would be hiding in shame.
Tuning + Driving, really simple!
Old Aug 3, 2002 | 07:42 AM
Turbo Laser's Avatar
Just get a B16 you loser.....
[Modified by NOCARLOSER, 3:45 PM 8/6/2002]
Old Aug 6, 2002 | 03:25 AM
Hybrid's Avatar
Default Re: Death of my D16Z6............ (NOCARLOSER)
Mistabone I've been on your site many times and have seen many posts you have on several site.
I consider you a sohc guru.
Do not hide in shame..................................guide the rest of us sohc followers.
Good work!
Old Aug 6, 2002 | 01:14 PM
Mista Bone's Avatar
D Tranny Guru
why spend $2,000 on a setup that is slower?
Old Aug 6, 2002 | 01:16 PM
LsTurbo91's Avatar
because its cool
Old Aug 6, 2002 | 01:51 PM
Kamin's Avatar
because i want to see what you can do with a REAL engine
hehe j/k
Old Aug 6, 2002 | 03:00 PM
technine's Avatar
Damn, 25 bottles and now it finally blows!?! And you were running 75hp jets right?! Master tuner
Old Aug 6, 2002 | 04:07 PM
Default Re: Death of my D16Z6............ (technine)
FYI...joking with the B16 comment. But didn't you know someone was gonna say it. I'm definitely sticking with my D series, unless I win the lottery.
Old Aug 6, 2002 | 05:19 PM
zcivic91's Avatar
hey when u say lack of n2o..how did that fug up the motor..wouldnt a lack of gas mess it up??
Old Aug 6, 2002 | 10:47 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Death of my D16Z6............ (zcivic91)
bottle was running empty, matter of fact less than .5 lb left in it after the LAST PASS
When you get liquid/gas/liquid/gas etc...... The pressure will vary. This varies the pressure that goes to the FPR that raises fuel pressure. Things get out of wack and you end up spraying liquid without any extra fuel.
Once things start melting with nitrous, it is like the China Syndrome if you don't catch it.
Element3488
Oct 3, 2012 07:17 PM
1LowSol
Mar 26, 2010 09:25 AM
The Up Garage
Oct 5, 2006 09:40 AM
95jeremie
Mar 14, 2004 03:16 PM
dynamicauto
Jan 17, 2004 05:25 PM
