Death of my D16Z6............
Re: Death of my D16Z6............ (CovertFI)
how long did this d-series run before it went? so what you got planned next bone? i'm sure you have something good in mind. good luck with ur next creation
D Tranny Guru
Re: Death of my D16Z6............ (Pengo)
lack of nitrous (empty bottle) did in the the motor.
I bought the motor with 55k on it from a well cared 95 EX Coupe. I installed it with a LW pulley and 10,000 miles later I had the bearing incident. I installed new Honda bearings (all GREEN!) and cleened up the crank with 600 grit emery cloth. Figuring the crank is trashed I found a used ZEX kit for $350 locally. Twenty five bottles or 250 lbs of nitrous later, I finally HURT it bad. I did melt a plug a year ago on #2 piston, 15% blowby.
Now, I only paid $500 for the motor AND tranny + axles. I had a BLAST and will do it all over again!
Swap/slicks/juice I had less than $1200 invested, name a DOHC B swap that can claim that?
Next plans are a D15B VTEC using a D15B7 block, VX rods, GX Y8 pistons, for a 12.5:1 compressoin 1.5L stomper. Expect low 14's all motor using factory parts.
Now, just think what I could do IF I had the money to play with a B swap?????
Alot of people would be hiding in shame.
Tuning + Driving, really simple!
Re: Death of my D16Z6............ (NOCARLOSER)
Mistabone I've been on your site many times and have seen many posts you have on several site.
I consider you a sohc guru.
Do not hide in shame..................................guide the rest of us sohc followers.
Good work!
Good work!
Re: Death of my D16Z6............ (Mista Bone)
why spend $2,000 on a setup that is slower?
hehe j/k
Re: Death of my D16Z6............ (technine)
FYI...joking with the B16 comment. But didn't you know someone was gonna say it. I'm definitely sticking with my D series, unless I win the lottery.
D Tranny Guru
Re: Death of my D16Z6............ (zcivic91)
bottle was running empty, matter of fact less than .5 lb left in it after the LAST PASS
When you get liquid/gas/liquid/gas etc...... The pressure will vary. This varies the pressure that goes to the FPR that raises fuel pressure. Things get out of wack and you end up spraying liquid without any extra fuel.
Once things start melting with nitrous, it is like the China Syndrome if you don't catch it.
