Lights dim when VTEC hits...?
Weird problem on my Z6; when the engine hits about 4900-5200 RPM (which is where VTEC kicks in usually), all my lights dim. It's pretty noticeable too, I'm not sure what could be the cause. Any ideas?
There was an alarm on the car when I bought it, but it wasn't functioning properly and I don't think it's hooked up. I do have beats though, I've got an amp and sub running in it.
did you get it prof. installed? cuz sometimes even the cheap shops will run it directly to your battery and it will drain your power....but still idk why it would dim only when your vtec hits...
check the ground on your thermostat housing. i know it sounds too simple but mine was doing it at about 3800. only thing i could figure when the motor rolled back (motor mounts all dead) it moved. prolly not it but easy fix if it is
Alternator is fine, just replaced the alternator and belt, timing belt and water pump about 2 weeks ago.
I'll check that tomorrow along with the rest of the grounds and wiring that I can.
Thanks for the input everyone.
all the more reason to check the alternator belt. just because you replaced it doesnt mean you got it tight enough
stopspazinout
May 31, 2011 07:21 AM
NFM_Dm
Nov 15, 2004 02:47 PM
97VtecIN
Nov 6, 2004 05:14 AM
haha jk prob the ground wire
